Socks5 BUG?
leftsee
Socks5 BUG?
Hi!
I have WINSCP2 and WinXP.
I know, that I'm able to connect with ssh2 to a server with another program (I've tried).
I'm behind a SOCKS5-Firewall and I think that's the problem.
I get following errors:
1a) (If I use logging)
"Assertion failed: (LogMemo->Parent == this) && (LogMemo->OnChange == LogMemoChange), file c:\Martin\Projekty\WinSCP2\forms\Log.cpp, line 77"
after that there is the following error:
1b)
"Abnormal program termination"
2) (If I don't use logging)
"gethostbyname: unknown error"
but I can connect to the same server with the other program.
I don't know, what it is!
So I cannot do anything with this until author of Putty fixes this. You may write him description of your problem.
