File Panel's Font Settings
GoldenWolf
Just today i buy Dell Inspiron 8600c with matrix size 1920x1200 -> i can't read standart font of WinSCP (too small)
It would be grate if you apply custom fonts for WInSCP!
P.S. Sorry for my english
goldenwolf
screenshot
Ofcourse, i can (screenshot of my desktop from 2 monitors (1024X768 + 1920x1200):
(i think, at your monitor that has normal appearance, but i really NEED to use larger fonts (if you can't do it customizable, may be you have any idea about direct changing of font of TUnixDirView (without recompilation of sources on my PC, may be changing of some windows registry values?)
Screenshot (<invalid hyperlink removed by admin>)
Re: screenshot
I've found that the file panales follow system-wide icon font settings. So I believe that instead of developing application specific settings, your should change your system icon font. It would make also Explorer's icon title larger, etc.
I have added this to F.A.Q.
I hope this helps you.
New User
Font Change
Hi Martin,
love your program, but as some users before me I have difficulties to read the letters in commander view on my small travel laptop.
Option for a bigger font would definetly make things easier for me.
Thanks for consideration.
MArtin
Re: Font Change
Have you read the FAQ?
