Resuming uploads
jbg_sm
Resuming uploads
I looked through the forums, but I did not find the append option when I tried to resume a file upload.
I am not sure what version of SFTP I have, if at all
Any help is appreciated.
jbg_sm wrote:
I don't think my server supports SFTP, & wasn't sure if your alt. method listed in the documentation applied to me... thx
Most of the current SSH servers support SFTP. What is your SSH server? The alternative method is supported with SFTP only too. SCP does not allow so start writting file at the end.
jbg_sm wrote:
I am running Linu RedHat Enterprise 3
I believe that there is a SFTP server. Why do you not think so?
jbg_sm
When I try to connec tusing only SFTP protocol (instead of with SCP fallback) I get this error message - Cannot initialize SFTP protocol. Connection has been unexpectedly closed. Server sent command exit status 127
maybe I'm doing s/thing wrong if I should have it.
thx
If you have access too SSH server log, please check it. The server has probably some problem running the SFTP server.
