Startup
Newbie1a
Startup
I was referred to this program in order that I may transfer files from my PC to another. I downloaded the package#122 onto my Windows ME. Trying to use the program I came up with the login screen. At this point I drew a blank. How does one login? Are there instructions for the program's use?
Scott :cry:
Re: Startup
In general WinSCP cannot be used to transfers files between two PCs, unless the one you're connecting to is running SSH server. If this is not your case, you cannot use WinSCP.
Newbie1a
Re: Startup
Purhaps I should clarify my previous ambiguity. I have a windows ME PC and a Zaurus (Linux) handheld with ssh joined by USB. I can ping both directions. Users have said they have been able to ssh into it. Does this change your reply?
Re: Startup
Yes it might work with this configuration. Just enter address of your handheld, username and password to login dialog.
