Excluded Files Mask - files without a fullstop (.)
Pascal
is it possible to exlude all files, that do not have a . (fullstop) in the name?
Because if i say "keep remote directory uptodate" and use the option delete files, WinSCP alway deletes my softlinks in the remotedirectory, but it is not possible to download them on a windows machine, so I can'T use the "keep remote directory uptodate".
Pascal
Re: Excluded Files Mask - files without a fullstop (.)
No, you can exlude only files that HAS something in the name. Anyway what do you mean by "fullstop"? I probably miss something :-) Also you have chance to succeed using range mask, like [a-z]. But that depends.
