kerberos
v_t_m
Re: kerberos
Currently I'am working on SSPI authentication for PuTTY. I will probably use a patch from Certified Security Solutions (<invalid hyperlink removed by admin>).
As this patch includes Kerberos autehtication for SSH1, maybe I will include this feature, too.
Werdhi
WinSCP not using Kerberos Tickets
Pardon my ignorance :? ... I use Keberos Authentication (MIT Leash Version 2.6.3.20040525) for obtaining a Kerberos ticket which both my e-mail programs then can use to log me into the server securely (I use Mulberry and Eudora). When I set up WinSCP to "Attempt MIT Kerberos 5 GSSAPI Authentication," I still get prompted for a password and the ticket I've already obtained is not used.
What am I doing wrong :?:
Thanks!
_________________
Windows XP Home (SP II)
PIV 2.4 Ghz
1 GB RAM
56k Dial-up
Werdhi
Log File
Here is the log file from start-up to closing the connection (I've edited some of the data to obscure the actual user names/IP addresses). As you can see, it does prompt me for a password even though I've already got a Kerberos 5 ticket.
Thanks for your help.
. WinSCP Version 3.7.2 (Build 262) (OS 5.1.2600 Service Pack 2)
. Login time: Monday, February 07, 2005 12:26:16 PM
. Session name: *Werdhi's IFS Space - Kerberized
. Host name: login.***.edu (Port: 22)
. User name: werdhi (Password: No, Key file: No)
. Transfer Protocol: SFTP (SCP)
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: Yes
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-
. SFTP Bugs: -,-
. Proxy: none
. Shell: default, EOL: 0
. Local directory: default, Remote directory: home, Update: No, Cache: Yes
. Cache directory changes: Yes, Permanent: Yes
. Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. Looking up host "login.***.edu"
. Connecting to ***.211.2.206 port 22
. Server version: SSH-1.99-OpenSSH_3.4p1
. We claim version: SSH-2.0-WinSCP_release_3.7.2
. Host key fingerprint is:
. ssh-rsa 1024 10:4a:ec:d2:f1:38:f7:ea:0a:a0:0f:17:57:ea:a6:16
. Initialised HMAC-SHA1 client->server MAC algorithm
. Initialised HMAC-SHA1 server->client MAC algorithm
! Using username "werdhi".
. Session password prompt (werdhi@login.***.edu's password: )
. Asking user for password.
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Using SFTP protocol.
> Type: SSH_FXP_INIT, Size: 5, Number: -1
< Type: SSH_FXP_VERSION, Size: 5, Number: -1
. SFTP version 3 negotiated.
> Type: SSH_FXP_EXTENDED, Size: 38, Number: 200
< Type: SSH_FXP_STATUS, Size: 38, Number: 200
< Status/error code: 8
. Server does not recognise WinSCP.
. Getting real path for '.'
> Type: SSH_FXP_REALPATH, Size: 10, Number: 528
< Type: SSH_FXP_NAME, Size: 79, Number: 528
. Real path is '/afs/***.edu/user/***'
. Listing directory "/afs/***.edu/user/***".
> Type: SSH_FXP_OPENDIR, Size: 38, Number: 779
< Type: SSH_FXP_HANDLE, Size: 13, Number: 779
> Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< Type: SSH_FXP_NAME, Size: 7169, Number: 1036
> Type: SSH_FXP_READDIR, Size: 13, Number: 1292
. Reading symlink ".cshrc".
> Type: SSH_FXP_READLINK, Size: 45, Number: 1555
> Type: SSH_FXP_STAT, Size: 45, Number: 1809
< Type: SSH_FXP_STATUS, Size: 28, Number: 1292
. Storing reserved response
< Type: SSH_FXP_NAME, Size: 47, Number: 1555
< Type: SSH_FXP_ATTRS, Size: 37, Number: 1809
. Reading symlink ".login".
> Type: SSH_FXP_READLINK, Size: 45, Number: 2067
> Type: SSH_FXP_STAT, Size: 45, Number: 2321
< Type: SSH_FXP_NAME, Size: 47, Number: 2067
< Type: SSH_FXP_ATTRS, Size: 37, Number: 2321
. Reading symlink ".logout".
> Type: SSH_FXP_READLINK, Size: 46, Number: 2579
> Type: SSH_FXP_STAT, Size: 46, Number: 2833
< Type: SSH_FXP_NAME, Size: 49, Number: 2579
< Type: SSH_FXP_ATTRS, Size: 37, Number: 2833
. Reading symlink ".mwmrc".
> Type: SSH_FXP_READLINK, Size: 45, Number: 3091
> Type: SSH_FXP_STAT, Size: 45, Number: 3345
< Type: SSH_FXP_NAME, Size: 47, Number: 3091
< Type: SSH_FXP_ATTRS, Size: 37, Number: 3345
. Reading symlink ".principals".
> Type: SSH_FXP_READLINK, Size: 50, Number: 3603
> Type: SSH_FXP_STAT, Size: 50, Number: 3857
< Type: SSH_FXP_NAME, Size: 57, Number: 3603
< Type: SSH_FXP_ATTRS, Size: 37, Number: 3857
. Reading symlink ".profile".
> Type: SSH_FXP_READLINK, Size: 47, Number: 4115
> Type: SSH_FXP_STAT, Size: 47, Number: 4369
< Type: SSH_FXP_NAME, Size: 51, Number: 4115
< Type: SSH_FXP_ATTRS, Size: 37, Number: 4369
. Reading symlink ".termsetup".
> Type: SSH_FXP_READLINK, Size: 49, Number: 4627
> Type: SSH_FXP_STAT, Size: 49, Number: 4881
< Type: SSH_FXP_NAME, Size: 55, Number: 4627
< Type: SSH_FXP_ATTRS, Size: 37, Number: 4881
. Reading symlink ".tvtwmrc".
> Type: SSH_FXP_READLINK, Size: 47, Number: 5139
> Type: SSH_FXP_STAT, Size: 47, Number: 5393
< Type: SSH_FXP_NAME, Size: 51, Number: 5139
< Type: SSH_FXP_ATTRS, Size: 37, Number: 5393
. Reading symlink ".twmrc".
> Type: SSH_FXP_READLINK, Size: 45, Number: 5651
> Type: SSH_FXP_STAT, Size: 45, Number: 5905
< Type: SSH_FXP_NAME, Size: 47, Number: 5651
< Type: SSH_FXP_ATTRS, Size: 37, Number: 5905
. Reading symlink ".xpattern".
> Type: SSH_FXP_READLINK, Size: 48, Number: 6163
> Type: SSH_FXP_STAT, Size: 48, Number: 6417
< Type: SSH_FXP_NAME, Size: 53, Number: 6163
< Type: SSH_FXP_ATTRS, Size: 37, Number: 6417
. Reading symlink ".xresources".
> Type: SSH_FXP_READLINK, Size: 50, Number: 6675
> Type: SSH_FXP_STAT, Size: 50, Number: 6929
< Type: SSH_FXP_NAME, Size: 57, Number: 6675
< Type: SSH_FXP_ATTRS, Size: 37, Number: 6929
. Reading symlink ".zephyr.subs".
> Type: SSH_FXP_READLINK, Size: 51, Number: 7187
> Type: SSH_FXP_STAT, Size: 51, Number: 7441
< Type: SSH_FXP_NAME, Size: 59, Number: 7187
< Type: SSH_FXP_ATTRS, Size: 37, Number: 7441
. Reading symlink ".zephyr.vars".
> Type: SSH_FXP_READLINK, Size: 51, Number: 7699
> Type: SSH_FXP_STAT, Size: 51, Number: 7953
< Type: SSH_FXP_NAME, Size: 59, Number: 7699
< Type: SSH_FXP_ATTRS, Size: 37, Number: 7953
. Reading symlink ".xsession".
> Type: SSH_FXP_READLINK, Size: 48, Number: 8211
> Type: SSH_FXP_STAT, Size: 48, Number: 8465
< Type: SSH_FXP_NAME, Size: 53, Number: 8211
< Type: SSH_FXP_ATTRS, Size: 37, Number: 8465
< Status/error code: 1
> Type: SSH_FXP_CLOSE, Size: 13, Number: 8708
. Startup conversation with host finished.
. Closing connection.
Re: Log File
I does not looks like your SSH server supportes GSSAPI (Kerberos). Are you sure it does? Are you able to login to it using Kerberos with any other SSH client? Which one?
Werdhi
Hmm ... I do use Kerberos for POP3 and IMAP e-mail with the University's server but I don't know enough to know whether I'm dealing with a whole different matter when using SFTP. I don't use any other SSH Client. I'll have to check with the IT folks to see if they have an idea regarding this. It may be that I cannot use Kerberos to upload/download to the AFS.
I'll get back to you.
Thank you,
werdhi
_________________
PIV 2.4 Ghz
1 GB RAM
56k Dial-up
