Get rid of the 'Ext' column
tmpsa
How can I get rid of the useless 'Ext' column? It does not have a button in the 'Show columns' menu.
Excellent software, congratulations!
Re: Get rid of the 'Ext' column
Ext is fake column, that should never display. I wonder how did you made it to show itself :-)
If you can work with Windows registry delete one of the following keys, depending on what interface are you using:
HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\Commander\LocalPanel\DirViewParams
HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\Commander\RemotePanel\DirViewParams
HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\Explorer\DirViewParams
Guigou wrote:
Sorry for digging the post, but the way to show this column is simple, press "CTRL + NUM+"
Thanks for reporting this. I have recently discovered this shortcut too. Will fix it.
