[ABORT] <- Host has not responded for 15sec.
swdave
I have only been experimenting with this app for a couple weeks and found it to be far better then all the other ...FTP apps out there thanks for all your work.
Usually when I have my net connection maxed and trying to download with WinSCP I get this [ABORT] message Host has not respond for 15 secs. Can you figure out a better way to present this so it does not activate the window and accept accidental keystrokes to abort.
Dave...
Re: [ABORT] <- Host has not responded for 15sec.
The window should not be activated, the task bar button should flash only. What version of Windows are you using WinSCP on?
XP Home
The task bar is only flashing but the abort message is there when I click it. It should at least be Yes/No with No as the default.
