cannot copy files from a drag operation - can only move
stgmike
seattle, washington
Since nobody else is reporting this, I think this must be due to something I am doing wrong, but I cannot figure it out! I can't find a configuration combination that will allow me to copy again (from a dragging operation).
I am using 3.7.1 (build 257) of WinSCP and When I drag a remote file to my desktop (or to any folder on my local computer) I am prompted to Move the file or Cancel. I used to be offered the opportunity to Copy the file (leave it on the remote server and copy it to my local computer).
I am using the Explorer interface (but I was before, too). Here is a snippet from my log.
. WinSCP Version 3.7.1 (Build 257) (OS 5.0.2195 Service Pack 4)
. Login time: Tuesday, December 14, 2004 4:21:48 PM
. Session name: CPHosting
. Host name: seattletech.com (Port: 22)
. User name: seattlet (Password: Yes, Key file: No)
. Transfer Protocol: SFTP (SCP)
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Local directory: default, Remote directory: home, Update: No, Cache: Yes
. Cache directory changes: Yes, Permanent: Yes
. Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. Looking up host "seattletech.com"
. Connecting to 216.67.254.38 port 22
. Server version: SSH-1.99-OpenSSH_3.1p1
. We believe remote version has SSH2 RSA padding bug
. We claim version: SSH-2.0-WinSCP-release-3.7.1
. Host key fingerprint is: <edited out>
. Initialised HMAC-SHA1 client->server MAC algorithm
. Initialised HMAC-SHA1 server->client MAC algorithm
! Using username <edited out>.
. Keyboard-interactive authentication refused
. Session password prompt (<edited out>'s password: )
. Using stored password.
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Using SFTP protocol.
> Type: SSH_FXP_INIT, Size: 5, Number: -1
< Type: SSH_FXP_VERSION, Size: 5, Number: -1
. SFTP version 3 negotiated.
> Type: SSH_FXP_EXTENDED, Size: 38, Number: 200
< Type: SSH_FXP_STATUS, Size: 38, Number: 200
< Status/error code: 8
. Server does not recognise WinSCP.
. Getting real path for '.'
> Type: SSH_FXP_REALPATH, Size: 10, Number: 528
< Type: SSH_FXP_NAME, Size: 49, Number: 528
. Real path is '/home/seattlet'
. Listing directory "/home/seattlet".
> Type: SSH_FXP_OPENDIR, Size: 23, Number: 779
< Type: SSH_FXP_HANDLE, Size: 13, Number: 779
> Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< Type: SSH_FXP_NAME, Size: 6689, Number: 1036
> Type: SSH_FXP_READDIR, Size: 13, Number: 1292
. Reading symlink "www".
> Type: SSH_FXP_READLINK, Size: 27, Number: 1555
> Type: SSH_FXP_STAT, Size: 27, Number: 1809
< Type: SSH_FXP_STATUS, Size: 28, Number: 1292
< Type: SSH_FXP_NAME, Size: 43, Number: 1555
< Type: SSH_FXP_ATTRS, Size: 37, Number: 1809
< Status/error code: 1
> Type: SSH_FXP_CLOSE, Size: 13, Number: 2052
< Type: SSH_FXP_STATUS, Size: 24, Number: 2052
< Status/error code: 0
. Startup conversation with host finished.
. Cached directory change via "public_html" to "/home/seattlet/public_html".
. Listing directory "/home/seattlet/public_html".
> Type: SSH_FXP_OPENDIR, Size: 35, Number: 2315
< Type: SSH_FXP_HANDLE, Size: 13, Number: 2315
> Type: SSH_FXP_READDIR, Size: 13, Number: 2572
< Type: SSH_FXP_NAME, Size: 8301, Number: 2572
> Type: SSH_FXP_READDIR, Size: 13, Number: 2828
. Reading symlink "bugbase".
> Type: SSH_FXP_READLINK, Size: 43, Number: 3091
> Type: SSH_FXP_STAT, Size: 43, Number: 3345
< Type: SSH_FXP_STATUS, Size: 28, Number: 2828
< Type: SSH_FXP_NAME, Size: 41, Number: 3091
< Type: SSH_FXP_ATTRS, Size: 37, Number: 3345
. Reading symlink "webcal".
> Type: SSH_FXP_READLINK, Size: 42, Number: 3603
> Type: SSH_FXP_STAT, Size: 42, Number: 3857
< Type: SSH_FXP_NAME, Size: 63, Number: 3603
< Type: SSH_FXP_ATTRS, Size: 37, Number: 3857
. Reading symlink "webreg".
> Type: SSH_FXP_READLINK, Size: 42, Number: 4115
> Type: SSH_FXP_STAT, Size: 42, Number: 4369
< Type: SSH_FXP_NAME, Size: 47, Number: 4115
< Type: SSH_FXP_ATTRS, Size: 37, Number: 4369
> Type: SSH_FXP_CLOSE, Size: 13, Number: 4612
< Type: SSH_FXP_STATUS, Size: 24, Number: 4612
. Cached directory change via "pdf" to "/home/seattlet/public_html/pdf".
. Listing directory "/home/seattlet/public_html/pdf".
> Type: SSH_FXP_OPENDIR, Size: 39, Number: 4875
< Type: SSH_FXP_HANDLE, Size: 13, Number: 4875
> Type: SSH_FXP_READDIR, Size: 13, Number: 5132
< Type: SSH_FXP_NAME, Size: 1253, Number: 5132
> Type: SSH_FXP_READDIR, Size: 13, Number: 5388
< Type: SSH_FXP_STATUS, Size: 28, Number: 5388
> Type: SSH_FXP_CLOSE, Size: 13, Number: 5636
< Type: SSH_FXP_STATUS, Size: 24, Number: 5636
Re: cannot copy files from a drag operation - can only move
Disabling "Allow moving from remote directory to other applications"? may help you. There are several topics on the forum that explain the problem in more details.
stgmike
seattle, washington
Thanks for pointing this out. Excellent product, excellent support!
- Mike
Since 5.14, it is always possible to use drag&drop to move remote files to external applications, while copy is always the default operation.
