Download file o 2 files maximum with one batch file...
yao-aztec
Mexico
Hi forum, From México, specially to Prikril, 'cause i see he is the C Builder Master, i (try to ) programm in C Builder Version 5 , since last year , but i never will be like u dude... u r the BIGEST FTP MASTER !!!!
Well, to my problem.
I try to make a Stored_Session, but i don't know how i can download one or two files maximum, e.i.:
i only write this in my batch file:
Winscp3.exe comer (where "comer" is my stored_session)
and after ??? :cry: , what i must write to download and close the session ????
If u can post code to download the files, i 'll be so happy man.
THX a lot.
Reply with quote E-mail
dl1eyg
Re: Download file o 2 files maximum with one batch file...
Hello prikryl,
I must transfering many files from Linux-Server to Windows-PC with SSH too. I try it with:
winscp3.exe root@elc /get /home/portal/backup/holen.txt /exit
WinSCP tried to load a stored session, but no files are transfered and a program not exit automatically.
what is there wrong?
thanks a lot
dl1eyg wrote:
Hello prikryl,
Have you read documentation? Anyway, I've added example script, to give you an idea.
instead of "have you read a docu" can you write a simple of example:
winscp3.com /script=[scriptname]
and in file [scriptname]:
get /PATH/FILENAME
this became already is enough !!!
:x :x :x
I cannot, because the answer is not only for you, but for everyone interested. And the other may not be as lazy as you to look at the doc and learn more. Also, I cannot understand how you can blame me for doing more for your that you need. I have wrote entire new doc chapter just for YOU!
