traverse only directories (e.g. chmod 110) and SFTP
Re: traverse only directories (e.g. chmod 110) and SFTP
I'm not sure if I'm willing to add the suggested workaround. It would fix this particular problem with OpenSSH server. Definitely soon, someone will ask for similar fix for specific behaviour for each other SSH server. Anyway I'll consider it, but I do not promise anything :-)
