SFTP
earl.timmerman
SFTP
I am trying to sftp a file from IBM Mainframe z/OS1.4 and file is unreadable. Is there a way of converting the file from EBCDIC to ASCII as the file is being transferred.
Earl
Re: SFTP
If the server supports SFTP v4, select text (ascii) transfer mode.
ghl1976
Sweden
Re: SFTP
Earl
If the file is a ascii or UTF8 encoded file, choose option binary and use iconv in omvs shell if you need to have it encoded as ebcdic.
