supercleanse
Recursive Synchronization
Is it possible to override the limit on the number of folders you can sychronize within the sub-directory structure of a directory? I am trying to synchronize my "My Documents" folder with a remote SSH server -- it has 1000+ folders and heavily nested. It would be nice if I could do this.
Site Admin -
- 43,055
- Prague, Czechia
Re: Recursive Synchronization
You you want to do one-time synchronisation only (not continuous one), use "Synchornize" command, which does not have a limit.
supercleanse
I am using the one-time synchronize command... I am using a script file that looks like this:
option batch on
option confirm on
option synchdelete off
synchronize remote "C:\Documents and Settings\supercleanse\My Documents" "/home/supercleanse/docs/My Documents"
What I'm seeing is that at a certain point in the synchronization, it stops and if I reinitiate the synchronization it just looks at the folders I just sync'ed and then exits -- as if there is some kind of hard-coded limit.
Thanks.
option batch on
option confirm on
Thanks.
supercleanse
Here's some more information -- it bombs out after syncing 191 directories with a maximum traversal depth of 6 directories. Oh, and the command I issue is as follows:
WinScp3.com supercleanse /script=c:/supercleanse.sync
The file called supercleanse.sync contains only the commands listed in my previous post:
option batch on
option confirm on
Thanks.
option batch on
option confirm on
Thanks.
Site Admin -
- 43,055
- Prague, Czechia
What does mean "bombs out"? Some error message? Or does it just stop?Here's some more information -- it bombs out after syncing 191 directories with a maximum traversal depth of 6 directories.
Can you see something specific on the directory where does it stop? Or on directories it does not enter?
supercleanse
I thought it was just stopping (because I was typing the command into the run dialog and the command prompt disappears instantly) but I typed the command into the command prompt and got this error message at the end of the sync:
C:\...\.Super Cleanse | 0 kB | 0.0 kB/s | binary | 0%
File or folder 'C:\mike\.Super Cleanse ' does not exist.
(A)bort, (R)etry, (S)kip: Abort
I think this file on my Hard Drive is corrupt -- and I can understand the program not liking a corrupt file, but shouldn't WinSCP just skip the corrupt file instead of aborting the whole process altogether? Is there a way to get it to skip files like this?
Thanks.
I
Thanks.
I
Site Admin -
- 43,055
- Prague, Czechia
> help option
batch on/off
Toggles batch mode (all prompts are automatically replied
negatively).
No.Is there a way to get it to skip files like this?
- strasharo
- 1
So, is it anyway to modify the traversal depth to be bigger than 6 dirs?
Site Admin -
There's no such limit.So, is it anyway to modify the traversal depth to be bigger than 6 dirs?
