Explorer View --tree-pane
Adem
I can't rename/delete stuff in the tree-pane, I have to go to its parent and do all that on the right-pane, is there a special reason for this. For directories taht contain a lot of child directories, this becomes a very painful thing to work around.
Secondly, and in similar vein, could you enable context menu stuff for directories for the items on the tree-pane too, please.
Re: Explorer View --tree-pane
I can add the functionality once, but it is difficult thing to do. So maybe later.
