several error codes during moving files on a RH9 based file server
Masterblaster
Thx this is the right programm for windows user to manage files on a linux system without GUI.
I am getting error codes ( f. e. 4 or 8 ) when moving folders containing files / single files on my rh9 based file server between mount point and directories.
I am logged in as root and the folders/ files are 777.
If I make the same operations through a ssh client there will be no error at all.
What i am doing wrong?
Is there a setting that has to be corrected?
Re: several error codes during moving files on a RH9 based file server
Have you tried other client to check if it is problem of the server or WinSCP?
I do not think this may be solved by any setting.
masterblaster
@Martin: I changed SFTP to SCp and now it works,
Do I have to have a FTP server running to use sftp ?
Copying files + folders from one mount point / directory to another does not work, only copying them to my client works.
Is it not possible?
No.
Is it not possible?
Tell me what exacly do you do to copy files.
@ martin :
I want to copy the folder test from mount point /data1 to /data2.
I am marking the folder test and go to "file" "copy" then there is predefined d:\my documents that is a local folder.
How can I copy the folder "test" to /data2 ?
File/Copy is for downloads only. To make copy remotelly use File/Duplicate.
Do you know how to intergrate a "custom command" to UNRAR Winrar files ?
I do not know unrar syntax, but you can inspire with untar/gzip example. I also do not know if you want to unrar the files locally or remotelly.
I tested unsuccessfully with untar and i do want to make everything remotely, that means on the server.
How can i integrate the custom command after winrar is installed ?
I do not understand. How do you want to run WinRar remotely on RedHat?
