error code 4 (server failure)
mdude
Hi all. When I try connecting to WinSCP (Win XP Pro) I am able to connect, but whenever I try to add folders to my server or upload any files, I receive the following error:
Error code: 4
Error message from server: Failure
Request code: 14
Does anyone know the root of this? I exited my firewall, and other people can connect to the server with different usernames and passwords (I am accessing a college shared network). Thank you.
--Scott
Re: error code 4 (server failure)
Error code: 4
Request code: 14
--Scott
Sorry all for the duplicate post. The error I receive when trying to upload files is:
Error code: 4
Request code: 6
The request code is 14 when I try to create new folders. Sorry again!
Only thing I can think of is some permissions problem. Can you upload files with other SCP/SFTP clients (even some command-line like PSCP from Putty package).
Brian
Hi, this is actually the person with the problem, my friend was just posting for me at the time.
I tried uploading the web pages and the changes I made using Macromedia Dreamweaver and it gets the error as well.
No settings have been changed since it was able to last upload/update files.
Any other suggestions?
And are you able to write the files if you login using terminal. Also try SCP protocol, maybe it will display more meaningful message.
Rafi
We had the exact same error, and after checking permissions and other things, it turned to be a simple problem .... filesystem was 100% full :)
Good luck!
Thanks for info!! I can help other users. Unfortunatelly OpenSSH SFTP servers have terrible error reporting.
PublisherGuest1230
Program Abnormal Termination from WinSCP Script
We are trying to PUT data to an SFTP site via script, but we suspect we've maxed out our disk quota so we are getting an SSH status/error code of 4. (see log excerpt below).
Since the disk quota is beyond our control, our immediate concern is being able to trap the error. Instead of a code 4 being returned to the DOS batch caller, we are getting a dialog box indicating there was an Abnormal program Termination which effectively stalls our automated process (it runs at 11 pm in evening).
A google search indicates that this issue was raised a couple years back. Would it be possible to revisit and hotfix this problem?
This is a terrific program by the way, and we have found the synchonize feature to be indispensable.
We're running Windows Server 2003 SP2.
Thank you.
--LOG FILE EXCERPT START
. 2009-07-09 11:49:12.837 Binary transfer mode selected.
. 2009-07-09 11:49:12.837 Checking existence of file.
> 2009-07-09 11:49:12.837 Type: SSH_FXP_LSTAT, Size: 79, Number: 263
< 2009-07-09 11:49:12.853 Type: SSH_FXP_STATUS, Size: 29, Number: 263
< 2009-07-09 11:49:12.853 Status/error code: 2
. 2009-07-09 11:49:12.853 Checking existence of partially transfered file.
> 2009-07-09 11:49:12.853 Type: SSH_FXP_LSTAT, Size: 88, Number: 519
< 2009-07-09 11:49:12.884 Type: SSH_FXP_ATTRS, Size: 37, Number: 519
. 2009-07-09 11:49:12.884 Resuming file transfer.
. 2009-07-09 11:49:12.884 Opening remote file.
> 2009-07-09 11:49:12.884 Type: SSH_FXP_OPEN, Size: 96, Number: 771
< 2009-07-09 11:49:12.884 Type: SSH_FXP_HANDLE, Size: 13, Number: 771
> 2009-07-09 11:49:12.884 Type: SSH_FXP_WRITE, Size: 4121, Number: 1286
< 2009-07-09 11:49:12.946 Status/error code: 4, Message: 2566, Server: Failure, Language:
. 2009-07-09 11:54:12.942 Waiting for data timed out, asking user what to do.
. 2009-07-09 11:54:12.942 Asking user:
. 2009-07-09 11:54:12.942 Host has not answered for 300 seconds.
. 2009-07-09 11:54:12.942 Wait for another 300 seconds? ()
. 2009-07-09 11:54:12.942 Attempt to close connection due to fatal exception:
* 2009-07-09 11:54:12.942 Terminated by user.
. 2009-07-09 11:54:12.942 Closing connection.
. 2009-07-09 11:54:12.942 Sending special code: 12
. 2009-07-09 11:54:12.942 Sent EOF message
. 2009-07-09 11:54:12.942 Fatal error while disposing the SFTP queue.
--When the abnormal program termination box pops up
--LOG FILE EXCERPT END
Re: Program Abnormal Termination from WinSCP Script
What version of WinSCP are you using? Have you tried the latest one? If you are able reproduce the problem with the latest one, can you send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
guest
same problem here
I try to download some files from a HP NonStop System.
I'm able to download files witch are stored on the server as ASCII files, but when I try to download files stored as binary I receive the following error:
Copying files from remote side failed.
Error code: 4
Request code: 5
I try to download same file using FileZilla and WS_FTP Pro and both of them work fine.
Is there some settings that I must use to download these files ?
guest
Please see bellow the log for this.
I retrieve the same error for version 419 and 423beta.
. 2009-08-26 12:24:40.952 --------------------------------------------------------------------------
. 2009-08-26 12:24:40.952 WinSCP Version 4.1.9 (Build 416) (OS 5.1.2600 Service Pack 2)
. 2009-08-26 12:24:40.952 Login time: Wednesday, August 26, 2009 12:24:40 PM
. 2009-08-26 12:24:40.952 Session name: down@10.10.7.21
. 2009-08-26 12:24:40.952 Host name: 10.10.7.17 (Port: 22)
. 2009-08-26 12:24:40.952 User name: down (Password: Yes, Key file: No)
. 2009-08-26 12:24:40.952 Tunnel: No
. 2009-08-26 12:24:40.952 Transfer Protocol: SFTP (SCP)
. 2009-08-26 12:24:40.952 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-08-26 12:24:40.952 Proxy: none
. 2009-08-26 12:24:40.952 SSH protocol version: 2; Compression: No
. 2009-08-26 12:24:40.952 Bypass authentication: No
. 2009-08-26 12:24:40.952 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-08-26 12:24:40.952 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-08-26 12:24:40.952 SSH Bugs: -,-,-,-,-,-,-,-
. 2009-08-26 12:24:40.952 SFTP Bugs: -,-
. 2009-08-26 12:24:40.952 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-08-26 12:24:40.952 Shell: default, EOL: 0
. 2009-08-26 12:24:40.952 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-08-26 12:24:40.952 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-08-26 12:24:40.952 Local directory: D:\Programe\WinSCP\winscp419, Remote directory: home, Update: No, Cache: Yes
. 2009-08-26 12:24:40.952 Cache directory changes: Yes, Permanent: Yes
. 2009-08-26 12:24:40.952 DST mode: 1
. 2009-08-26 12:24:40.983 Looking up host "10.10.7.17"
. 2009-08-26 12:24:40.983 Connecting to 10.10.7.17 port 22
. 2009-08-26 12:24:41.124 Server version: SSH-2.0-1.36 sshlib: T9999G06_15Apr2008_comForte_SSH2_0079
. 2009-08-26 12:24:41.124 We claim version: SSH-2.0-WinSCP_release_4.1.9
. 2009-08-26 12:24:41.139 SSPI: acquired credentials for: user
. 2009-08-26 12:24:41.139 Cannot convert IP address to SPN: DNS is not trusted
. 2009-08-26 12:24:41.139 GSSKEX disabled: The operation completed successfully.. 2009-08-26 12:24:41.139 Using SSH protocol version 2
. 2009-08-26 12:24:41.186 Using Diffie-Hellman with standard group "group1"
. 2009-08-26 12:24:41.186 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-08-26 12:24:41.421 Host key fingerprint is:
. 2009-08-26 12:24:41.421 ssh-dss 1024 22:a3:1e:60:52:95:11:62:be:5a:60:4c:7f:75:f5:04
. 2009-08-26 12:24:41.421 Initialised AES-256 CBC client->server encryption
. 2009-08-26 12:24:41.421 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-08-26 12:24:41.483 Initialised AES-256 CBC server->client encryption
. 2009-08-26 12:24:41.483 Initialised HMAC-SHA1 server->client MAC algorithm
! 2009-08-26 12:24:41.530 Using username "down".
. 2009-08-26 12:24:41.624 Prompt (6, SSH password, , &Password: )
. 2009-08-26 12:24:41.624 Using stored password.
. 2009-08-26 12:24:41.624 Sent password
. 2009-08-26 12:24:42.905 Access granted
. 2009-08-26 12:24:42.967 Opened channel for session
. 2009-08-26 12:24:43.921 Started a shell/command
. 2009-08-26 12:24:43.921 --------------------------------------------------------------------------
. 2009-08-26 12:24:43.921 Using SFTP protocol.
. 2009-08-26 12:24:43.936 Doing startup conversation with host.
> 2009-08-26 12:24:43.936 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-08-26 12:24:43.983 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-08-26 12:24:43.983 SFTP version 3 negotiated.
. 2009-08-26 12:24:43.983 We believe the server has signed timestamps bug
. 2009-08-26 12:24:43.983 We will use UTF-8 strings for status messages only
. 2009-08-26 12:24:43.983 Getting current directory name.
. 2009-08-26 12:24:43.983 Getting real path for '.'
> 2009-08-26 12:24:43.983 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-08-26 12:24:44.046 Type: SSH_FXP_NAME, Size: 55, Number: 16
. 2009-08-26 12:24:44.046 Real path is 'upl'
. 2009-08-26 12:24:44.046 Listing directory "upl".
> 2009-08-26 12:24:44.046 Type: SSH_FXP_OPENDIR, Size: 26, Number: 267
< 2009-08-26 12:24:44.108 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2009-08-26 12:24:44.108 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2009-08-26 12:24:44.171 Type: SSH_FXP_NAME, Size: 455, Number: 524
> 2009-08-26 12:24:44.171 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2009-08-26 12:24:44.217 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2009-08-26 12:24:44.217 Status/error code: 1
> 2009-08-26 12:24:44.217 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2009-08-26 12:24:44.217 Startup conversation with host finished.
. 2009-08-26 12:24:47.061 Cached directory change via "/G" to "/G".
. 2009-08-26 12:24:47.061 Getting current directory name.
. 2009-08-26 12:24:47.061 Listing directory "/G".
> 2009-08-26 12:24:47.061 Type: SSH_FXP_OPENDIR, Size: 11, Number: 1291
< 2009-08-26 12:24:47.061 Type: SSH_FXP_STATUS, Size: 24, Number: 1028
. 2009-08-26 12:24:47.061 Discarding reserved response
< 2009-08-26 12:24:47.124 Type: SSH_FXP_HANDLE, Size: 13, Number: 1291
> 2009-08-26 12:24:47.124 Type: SSH_FXP_READDIR, Size: 13, Number: 1548
< 2009-08-26 12:24:47.952 Type: SSH_FXP_NAME, Size: 10787, Number: 1548
> 2009-08-26 12:24:47.952 Type: SSH_FXP_READDIR, Size: 13, Number: 1804
< 2009-08-26 12:24:48.358 Type: SSH_FXP_NAME, Size: 10809, Number: 1804
> 2009-08-26 12:24:48.358 Type: SSH_FXP_READDIR, Size: 13, Number: 2060
< 2009-08-26 12:24:48.780 Type: SSH_FXP_NAME, Size: 10807, Number: 2060
> 2009-08-26 12:24:48.780 Type: SSH_FXP_READDIR, Size: 13, Number: 2316
< 2009-08-26 12:24:49.030 Type: SSH_FXP_NAME, Size: 3029, Number: 2316
> 2009-08-26 12:24:49.030 Type: SSH_FXP_READDIR, Size: 13, Number: 2572
< 2009-08-26 12:24:49.092 Type: SSH_FXP_STATUS, Size: 28, Number: 2572
< 2009-08-26 12:24:49.092 Status/error code: 1
> 2009-08-26 12:24:49.092 Type: SSH_FXP_CLOSE, Size: 13, Number: 2820
. 2009-08-26 12:24:54.702 Cached directory change via "bpbu01" to "upl".
. 2009-08-26 12:24:54.702 Getting current directory name.
. 2009-08-26 12:24:54.702 Listing directory "upl".
> 2009-08-26 12:24:54.702 Type: SSH_FXP_OPENDIR, Size: 18, Number: 3083
< 2009-08-26 12:24:54.702 Type: SSH_FXP_STATUS, Size: 24, Number: 2820
. 2009-08-26 12:24:54.702 Discarding reserved response
< 2009-08-26 12:24:54.858 Type: SSH_FXP_HANDLE, Size: 13, Number: 3083
> 2009-08-26 12:24:54.858 Type: SSH_FXP_READDIR, Size: 13, Number: 3340
< 2009-08-26 12:24:54.952 Type: SSH_FXP_NAME, Size: 1339, Number: 3340
> 2009-08-26 12:24:54.952 Type: SSH_FXP_READDIR, Size: 13, Number: 3596
< 2009-08-26 12:24:54.999 Type: SSH_FXP_STATUS, Size: 28, Number: 3596
< 2009-08-26 12:24:54.999 Status/error code: 1
> 2009-08-26 12:24:54.999 Type: SSH_FXP_CLOSE, Size: 13, Number: 3844
. 2009-08-26 12:24:58.874 Cached directory change via "dbn" to "upl/dbn".
. 2009-08-26 12:24:58.874 Getting current directory name.
. 2009-08-26 12:24:58.874 Listing directory "upl/dbn".
> 2009-08-26 12:24:58.874 Type: SSH_FXP_OPENDIR, Size: 26, Number: 4107
< 2009-08-26 12:24:58.874 Type: SSH_FXP_STATUS, Size: 24, Number: 3844
. 2009-08-26 12:24:58.874 Discarding reserved response
< 2009-08-26 12:24:58.952 Type: SSH_FXP_HANDLE, Size: 13, Number: 4107
> 2009-08-26 12:24:58.952 Type: SSH_FXP_READDIR, Size: 13, Number: 4364
< 2009-08-26 12:24:59.217 Type: SSH_FXP_NAME, Size: 11205, Number: 4364
> 2009-08-26 12:24:59.217 Type: SSH_FXP_READDIR, Size: 13, Number: 4620
< 2009-08-26 12:24:59.921 Type: SSH_FXP_NAME, Size: 11203, Number: 4620
> 2009-08-26 12:24:59.921 Type: SSH_FXP_READDIR, Size: 13, Number: 4876
< 2009-08-26 12:25:00.327 Type: SSH_FXP_NAME, Size: 11204, Number: 4876
> 2009-08-26 12:25:00.327 Type: SSH_FXP_READDIR, Size: 13, Number: 5132
< 2009-08-26 12:25:00.561 Type: SSH_FXP_NAME, Size: 6618, Number: 5132
> 2009-08-26 12:25:00.561 Type: SSH_FXP_READDIR, Size: 13, Number: 5388
< 2009-08-26 12:25:00.608 Type: SSH_FXP_STATUS, Size: 28, Number: 5388
< 2009-08-26 12:25:00.608 Status/error code: 1
> 2009-08-26 12:25:00.608 Type: SSH_FXP_CLOSE, Size: 13, Number: 5636
. 2009-08-26 12:25:06.327 File: "upl/dbn/test"
. 2009-08-26 12:25:06.327 Copying "upl/dbn/test" to local directory started.
. 2009-08-26 12:25:06.327 Binary transfer mode selected.
. 2009-08-26 12:25:06.327 Checking existence of partially transfered file.
. 2009-08-26 12:25:06.327 Opening remote file.
> 2009-08-26 12:25:06.327 Type: SSH_FXP_OPEN, Size: 43, Number: 5891
< 2009-08-26 12:25:06.327 Type: SSH_FXP_STATUS, Size: 24, Number: 5636
. 2009-08-26 12:25:06.327 Discarding reserved response
< 2009-08-26 12:25:06.639 Type: SSH_FXP_HANDLE, Size: 13, Number: 5891
> 2009-08-26 12:25:06.639 Type: SSH_FXP_FSTAT, Size: 13, Number: 6152
> 2009-08-26 12:25:06.639 Type: SSH_FXP_READ, Size: 25, Number: 6405
. 2009-08-26 12:25:06.702 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2009-08-26 12:25:06.702 Type: SSH_FXP_ATTRS, Size: 37, Number: 6152
. 2009-08-26 12:25:06.702 Storing reserved response
< 2009-08-26 12:25:07.061 Status/error code: 4, Message: 8197, Server: Failure, Language:
. 2009-08-26 12:25:07.249 18 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-26 12:25:07.249 Type: SSH_FXP_CLOSE, Size: 13, Number: 9220
* 2009-08-26 12:25:07.249 (ECommand) Copying files from remote side failed.
* 2009-08-26 12:25:07.249 General failure (server should provide error description).
* 2009-08-26 12:25:07.249 Error code: 4
* 2009-08-26 12:25:07.249 Error message from server: Failure
* 2009-08-26 12:25:07.249 Request code: 5
. 2009-08-26 12:25:10.311 Closing connection.
. 2009-08-26 12:25:10.311 Sending special code: 12
. 2009-08-26 12:25:10.311 Sent EOF message
You wrote about download before. But the log shows upload. So is it upload? Can you post a log file from Filezilla as well?
download files from tandem OS
Bellow you can find log from WinSCP 419, 424 and FileZilla 3.2.7.1.
Sorry for my big post.
Log from WinSCP 419:
. 2009-10-27 16:31:49.225 --------------------------------------------------------------------------
. 2009-10-27 16:31:49.225 WinSCP Version 4.1.9 (Build 416) (OS 5.1.2600 Service Pack 2)
. 2009-10-27 16:31:49.225 Login time: Tuesday, October 27, 2009 4:31:49 PM
. 2009-10-27 16:31:49.225 Session name: user@10.10.5.15
. 2009-10-27 16:31:49.225 Host name: 10.10.5.15 (Port: 22)
. 2009-10-27 16:31:49.225 User name: user (Password: Yes, Key file: No)
. 2009-10-27 16:31:49.225 Tunnel: No
. 2009-10-27 16:31:49.225 Transfer Protocol: SFTP (SCP)
. 2009-10-27 16:31:49.225 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-10-27 16:31:49.225 Proxy: none
. 2009-10-27 16:31:49.225 SSH protocol version: 2; Compression: No
. 2009-10-27 16:31:49.225 Bypass authentication: No
. 2009-10-27 16:31:49.225 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-10-27 16:31:49.225 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-10-27 16:31:49.225 SSH Bugs: -,-,-,-,-,-,-,-
. 2009-10-27 16:31:49.225 SFTP Bugs: -,-
. 2009-10-27 16:31:49.225 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-10-27 16:31:49.225 Shell: default, EOL: 0
. 2009-10-27 16:31:49.225 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-10-27 16:31:49.225 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-10-27 16:31:49.225 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-10-27 16:31:49.225 Cache directory changes: Yes, Permanent: Yes
. 2009-10-27 16:31:49.225 DST mode: 1
. 2009-10-27 16:31:49.256 Looking up host "10.10.5.15"
. 2009-10-27 16:31:49.256 Connecting to 10.10.5.15 port 22
. 2009-10-27 16:31:49.459 Server version: SSH-2.0-1.36 sshlib: T9999G06_15Apr2008_comForte_SSH2_0079
. 2009-10-27 16:31:49.459 We claim version: SSH-2.0-WinSCP_release_4.1.9
. 2009-10-27 16:31:49.475 SSPI: acquired credentials for: user@domain
. 2009-10-27 16:31:49.475 Cannot convert IP address to SPN: DNS is not trusted
. 2009-10-27 16:31:49.475 GSSKEX disabled: The operation completed successfully.
. 2009-10-27 16:31:49.475 Using SSH protocol version 2
. 2009-10-27 16:31:49.553 Using Diffie-Hellman with standard group "group1"
. 2009-10-27 16:31:49.553 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-10-27 16:31:49.881 Host key fingerprint is:
. 2009-10-27 16:31:49.881 ssh-dss 1024 22:a3:1e:60:52:95:11:62:be:5a:60:4c:7f:75:f5:04
. 2009-10-27 16:31:49.881 Initialised AES-256 CBC client->server encryption
. 2009-10-27 16:31:49.881 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-10-27 16:31:49.975 Initialised AES-256 CBC server->client encryption
. 2009-10-27 16:31:49.975 Initialised HMAC-SHA1 server->client MAC algorithm
! 2009-10-27 16:31:50.069 Using username "user".
. 2009-10-27 16:31:50.178 Prompt (6, SSH password, , &Password: )
. 2009-10-27 16:31:50.178 Using stored password.
. 2009-10-27 16:31:50.178 Sent password
. 2009-10-27 16:31:51.303 Access granted
. 2009-10-27 16:31:51.397 Opened channel for session
. 2009-10-27 16:31:51.803 Started a shell/command
. 2009-10-27 16:31:51.803 --------------------------------------------------------------------------
. 2009-10-27 16:31:51.803 Using SFTP protocol.
. 2009-10-27 16:31:51.803 Doing startup conversation with host.
> 2009-10-27 16:31:51.803 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-10-27 16:31:51.897 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-10-27 16:31:51.897 SFTP version 3 negotiated.
. 2009-10-27 16:31:51.897 We believe the server has signed timestamps bug
. 2009-10-27 16:31:51.897 We will use UTF-8 strings for status messages only
. 2009-10-27 16:31:51.897 Getting current directory name.
. 2009-10-27 16:31:51.897 Getting real path for '.'
> 2009-10-27 16:31:51.897 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-10-27 16:31:52.006 Type: SSH_FXP_NAME, Size: 55, Number: 16
. 2009-10-27 16:31:52.006 Real path is '/G/test00/test'
. 2009-10-27 16:31:52.006 Listing directory "/G/test00/test".
> 2009-10-27 16:31:52.006 Type: SSH_FXP_OPENDIR, Size: 26, Number: 267
< 2009-10-27 16:31:52.147 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2009-10-27 16:31:52.147 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2009-10-27 16:31:52.241 Type: SSH_FXP_NAME, Size: 345, Number: 524
> 2009-10-27 16:31:52.241 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2009-10-27 16:31:52.334 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2009-10-27 16:31:52.334 Status/error code: 1
> 2009-10-27 16:31:52.334 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2009-10-27 16:31:52.334 Startup conversation with host finished.
. 2009-10-27 16:31:54.178 Changing directory to "/G/test00".
. 2009-10-27 16:31:54.178 Getting real path for '/G/test00'
> 2009-10-27 16:31:54.178 Type: SSH_FXP_REALPATH, Size: 18, Number: 1296
< 2009-10-27 16:31:54.178 Type: SSH_FXP_STATUS, Size: 24, Number: 1028
. 2009-10-27 16:31:54.178 Discarding reserved response
< 2009-10-27 16:31:54.272 Type: SSH_FXP_NAME, Size: 39, Number: 1296
. 2009-10-27 16:31:54.272 Real path is '/G/test00'
. 2009-10-27 16:31:54.272 Trying to open directory "/G/test00".
> 2009-10-27 16:31:54.272 Type: SSH_FXP_LSTAT, Size: 18, Number: 1543
< 2009-10-27 16:31:54.381 Type: SSH_FXP_ATTRS, Size: 37, Number: 1543
. 2009-10-27 16:31:54.381 Getting current directory name.
. 2009-10-27 16:31:54.381 Listing directory "/G/test00".
> 2009-10-27 16:31:54.381 Type: SSH_FXP_OPENDIR, Size: 18, Number: 1803
< 2009-10-27 16:31:54.491 Type: SSH_FXP_HANDLE, Size: 13, Number: 1803
> 2009-10-27 16:31:54.491 Type: SSH_FXP_READDIR, Size: 13, Number: 2060
< 2009-10-27 16:31:54.928 Type: SSH_FXP_NAME, Size: 4793, Number: 2060
> 2009-10-27 16:31:54.928 Type: SSH_FXP_READDIR, Size: 13, Number: 2316
< 2009-10-27 16:31:55.022 Type: SSH_FXP_STATUS, Size: 28, Number: 2316
< 2009-10-27 16:31:55.022 Status/error code: 1
> 2009-10-27 16:31:55.022 Type: SSH_FXP_CLOSE, Size: 13, Number: 2564
. 2009-10-27 16:31:59.866 Cached directory change via "/G/test01/test" to "/G/test01/test".
. 2009-10-27 16:31:59.866 Getting current directory name.
. 2009-10-27 16:31:59.866 Listing directory "/G/test01/test".
> 2009-10-27 16:31:59.866 Type: SSH_FXP_OPENDIR, Size: 26, Number: 2827
< 2009-10-27 16:31:59.866 Type: SSH_FXP_STATUS, Size: 24, Number: 2564
. 2009-10-27 16:31:59.866 Discarding reserved response
< 2009-10-27 16:32:00.022 Type: SSH_FXP_HANDLE, Size: 13, Number: 2827
> 2009-10-27 16:32:00.022 Type: SSH_FXP_READDIR, Size: 13, Number: 3084
< 2009-10-27 16:32:00.397 Type: SSH_FXP_NAME, Size: 11205, Number: 3084
> 2009-10-27 16:32:00.397 Type: SSH_FXP_READDIR, Size: 13, Number: 3340
< 2009-10-27 16:32:00.772 Type: SSH_FXP_NAME, Size: 11203, Number: 3340
> 2009-10-27 16:32:00.772 Type: SSH_FXP_READDIR, Size: 13, Number: 3596
< 2009-10-27 16:32:01.085 Type: SSH_FXP_NAME, Size: 11204, Number: 3596
> 2009-10-27 16:32:01.085 Type: SSH_FXP_READDIR, Size: 13, Number: 3852
< 2009-10-27 16:32:01.444 Type: SSH_FXP_NAME, Size: 7402, Number: 3852
> 2009-10-27 16:32:01.444 Type: SSH_FXP_READDIR, Size: 13, Number: 4108
< 2009-10-27 16:32:01.585 Type: SSH_FXP_STATUS, Size: 28, Number: 4108
< 2009-10-27 16:32:01.585 Status/error code: 1
> 2009-10-27 16:32:01.585 Type: SSH_FXP_CLOSE, Size: 13, Number: 4356
. 2009-10-27 16:32:11.194 File: "/G/test01/test/file"
. 2009-10-27 16:32:11.194 Copying "/G/test01/test/file" to local directory started.
. 2009-10-27 16:32:11.194 Binary transfer mode selected.
. 2009-10-27 16:32:11.194 Checking existence of partially transfered file.
. 2009-10-27 16:32:11.194 Opening remote file.
> 2009-10-27 16:32:11.194 Type: SSH_FXP_OPEN, Size: 43, Number: 4611
< 2009-10-27 16:32:11.194 Type: SSH_FXP_STATUS, Size: 24, Number: 4356
. 2009-10-27 16:32:11.194 Discarding reserved response
< 2009-10-27 16:32:11.319 Type: SSH_FXP_HANDLE, Size: 13, Number: 4611
> 2009-10-27 16:32:11.319 Type: SSH_FXP_FSTAT, Size: 13, Number: 4872
> 2009-10-27 16:32:11.319 Type: SSH_FXP_READ, Size: 25, Number: 5125
. 2009-10-27 16:32:11.413 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2009-10-27 16:32:11.413 Type: SSH_FXP_ATTRS, Size: 37, Number: 4872
. 2009-10-27 16:32:11.413 Storing reserved response
< 2009-10-27 16:32:11.929 Status/error code: 4, Message: 6917, Server: Failure, Language:
. 2009-10-27 16:32:12.226 18 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-10-27 16:32:12.226 Type: SSH_FXP_CLOSE, Size: 13, Number: 7940
* 2009-10-27 16:32:12.226 (ECommand) Copying files from remote side failed.
* 2009-10-27 16:32:12.226 General failure (server should provide error description).
* 2009-10-27 16:32:12.226 Error code: 4
* 2009-10-27 16:32:12.226 Error message from server: Failure
* 2009-10-27 16:32:12.226 Request code: 5
. 2009-10-27 16:32:15.460 Closing connection.
. 2009-10-27 16:32:15.460 Sending special code: 12
. 2009-10-27 16:32:15.460 Sent EOF message
Log from WinSCP 424:
. 2009-10-27 16:37:57.251 --------------------------------------------------------------------------
. 2009-10-27 16:37:57.251 WinSCP Version 4.2.4 (Build 610) (OS 5.1.2600 Service Pack 2)
. 2009-10-27 16:37:57.251 Login time: Tuesday, October 27, 2009 4:37:57 PM
. 2009-10-27 16:37:57.251 Session name: user@10.10.5.15
. 2009-10-27 16:37:57.251 Host name: 10.10.5.15 (Port: 22)
. 2009-10-27 16:37:57.251 User name: user (Password: Yes, Key file: No)
. 2009-10-27 16:37:57.251 Tunnel: No
. 2009-10-27 16:37:57.251 Transfer Protocol: SFTP (SCP)
. 2009-10-27 16:37:57.251 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-10-27 16:37:57.251 Proxy: none
. 2009-10-27 16:37:57.251 SSH protocol version: 2; Compression: No
. 2009-10-27 16:37:57.251 Bypass authentication: No
. 2009-10-27 16:37:57.251 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-10-27 16:37:57.251 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-10-27 16:37:57.251 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2009-10-27 16:37:57.251 SFTP Bugs: -,-
. 2009-10-27 16:37:57.251 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-10-27 16:37:57.251 Shell: default, EOL: 0
. 2009-10-27 16:37:57.251 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-10-27 16:37:57.251 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-10-27 16:37:57.251 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-10-27 16:37:57.251 Cache directory changes: Yes, Permanent: Yes
. 2009-10-27 16:37:57.251 DST mode: 1
. 2009-10-27 16:37:57.283 Looking up host "10.10.5.15"
. 2009-10-27 16:37:57.283 Connecting to 10.10.5.15 port 22
. 2009-10-27 16:37:57.548 Server version: SSH-2.0-1.36 sshlib: T9999G06_15Apr2008_comForte_SSH2_0079
. 2009-10-27 16:37:57.548 Using SSH protocol version 2
. 2009-10-27 16:37:57.548 We claim version: SSH-2.0-WinSCP_release_4.2.4
. 2009-10-27 16:37:57.642 Using Diffie-Hellman with standard group "group1"
. 2009-10-27 16:37:57.642 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-10-27 16:37:57.908 Asking user:
. 2009-10-27 16:37:57.908 The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is.
. 2009-10-27 16:37:57.908 The server's dss key fingerprint is:
. 2009-10-27 16:37:57.908 ssh-dss 1024 22:a3:1e:60:52:95:11:62:be:5a:60:4c:7f:75:f5:04
. 2009-10-27 16:37:57.908 If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel.
. 2009-10-27 16:37:57.908 Continue connecting and add host key to the cache? ()
. 2009-10-27 16:37:59.752 Host key fingerprint is:
. 2009-10-27 16:37:59.752 ssh-dss 1024 22:a3:1e:60:52:95:11:62:be:5a:60:4c:7f:75:f5:04
. 2009-10-27 16:37:59.752 Initialised AES-256 CBC client->server encryption
. 2009-10-27 16:37:59.752 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-10-27 16:37:59.752 Initialised AES-256 CBC server->client encryption
. 2009-10-27 16:37:59.752 Initialised HMAC-SHA1 server->client MAC algorithm
! 2009-10-27 16:37:59.986 Using username "user".
. 2009-10-27 16:38:00.080 Prompt (6, SSH password, , &Password: )
. 2009-10-27 16:38:00.080 Using stored password.
. 2009-10-27 16:38:00.080 Sent password
. 2009-10-27 16:38:00.987 Access granted
. 2009-10-27 16:38:01.080 Opened channel for session
. 2009-10-27 16:38:01.674 Started a shell/command
. 2009-10-27 16:38:01.674 --------------------------------------------------------------------------
. 2009-10-27 16:38:01.674 Using SFTP protocol.
. 2009-10-27 16:38:01.674 Doing startup conversation with host.
> 2009-10-27 16:38:01.674 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-10-27 16:38:01.768 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-10-27 16:38:01.768 SFTP version 3 negotiated.
. 2009-10-27 16:38:01.768 We believe the server has signed timestamps bug
. 2009-10-27 16:38:01.768 We will use UTF-8 strings for status messages only
. 2009-10-27 16:38:01.784 Getting current directory name.
. 2009-10-27 16:38:01.784 Getting real path for '.'
> 2009-10-27 16:38:01.784 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-10-27 16:38:01.862 Type: SSH_FXP_NAME, Size: 55, Number: 16
. 2009-10-27 16:38:01.862 Real path is '/G/test00/test'
. 2009-10-27 16:38:01.862 Listing directory "/G/test00/test".
> 2009-10-27 16:38:01.862 Type: SSH_FXP_OPENDIR, Size: 26, Number: 267
< 2009-10-27 16:38:01.971 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2009-10-27 16:38:01.971 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2009-10-27 16:38:02.065 Type: SSH_FXP_NAME, Size: 345, Number: 524
> 2009-10-27 16:38:02.065 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2009-10-27 16:38:02.159 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2009-10-27 16:38:02.159 Status code: 1
> 2009-10-27 16:38:02.159 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2009-10-27 16:38:02.159 Startup conversation with host finished.
. 2009-10-27 16:38:07.066 Changing directory to "/G/test01/test".
. 2009-10-27 16:38:07.066 Getting real path for '/G/test01/test'
> 2009-10-27 16:38:07.066 Type: SSH_FXP_REALPATH, Size: 26, Number: 1296
< 2009-10-27 16:38:07.066 Type: SSH_FXP_STATUS, Size: 24, Number: 1028
. 2009-10-27 16:38:07.066 Discarding reserved response
< 2009-10-27 16:38:07.160 Type: SSH_FXP_NAME, Size: 55, Number: 1296
. 2009-10-27 16:38:07.160 Real path is '/G/test01/test'
. 2009-10-27 16:38:07.160 Trying to open directory "/G/test01/test".
> 2009-10-27 16:38:07.160 Type: SSH_FXP_LSTAT, Size: 26, Number: 1543
< 2009-10-27 16:38:07.254 Type: SSH_FXP_ATTRS, Size: 37, Number: 1543
. 2009-10-27 16:38:07.254 Getting current directory name.
. 2009-10-27 16:38:07.254 Listing directory "/G/test01/test".
> 2009-10-27 16:38:07.254 Type: SSH_FXP_OPENDIR, Size: 26, Number: 1803
< 2009-10-27 16:38:07.410 Type: SSH_FXP_HANDLE, Size: 13, Number: 1803
> 2009-10-27 16:38:07.410 Type: SSH_FXP_READDIR, Size: 13, Number: 2060
< 2009-10-27 16:38:07.816 Type: SSH_FXP_NAME, Size: 11205, Number: 2060
> 2009-10-27 16:38:07.816 Type: SSH_FXP_READDIR, Size: 13, Number: 2316
< 2009-10-27 16:38:08.238 Type: SSH_FXP_NAME, Size: 11203, Number: 2316
> 2009-10-27 16:38:08.238 Type: SSH_FXP_READDIR, Size: 13, Number: 2572
< 2009-10-27 16:38:08.738 Type: SSH_FXP_NAME, Size: 11204, Number: 2572
> 2009-10-27 16:38:08.738 Type: SSH_FXP_READDIR, Size: 13, Number: 2828
< 2009-10-27 16:38:08.973 Type: SSH_FXP_NAME, Size: 7402, Number: 2828
> 2009-10-27 16:38:08.973 Type: SSH_FXP_READDIR, Size: 13, Number: 3084
< 2009-10-27 16:38:09.051 Type: SSH_FXP_STATUS, Size: 28, Number: 3084
< 2009-10-27 16:38:09.051 Status code: 1
> 2009-10-27 16:38:09.051 Type: SSH_FXP_CLOSE, Size: 13, Number: 3332
. 2009-10-27 16:38:19.866 File: "/G/test01/test/file"
. 2009-10-27 16:38:19.866 Copying "/G/test01/test/file" to local directory started.
. 2009-10-27 16:38:19.866 Binary transfer mode selected.
. 2009-10-27 16:38:19.866 Checking existence of partially transfered file.
. 2009-10-27 16:38:19.866 Opening remote file.
> 2009-10-27 16:38:19.866 Type: SSH_FXP_OPEN, Size: 43, Number: 3587
< 2009-10-27 16:38:19.866 Type: SSH_FXP_STATUS, Size: 24, Number: 3332
. 2009-10-27 16:38:19.866 Discarding reserved response
< 2009-10-27 16:38:20.116 Type: SSH_FXP_HANDLE, Size: 13, Number: 3587
> 2009-10-27 16:38:20.116 Type: SSH_FXP_FSTAT, Size: 13, Number: 3848
> 2009-10-27 16:38:20.116 Type: SSH_FXP_READ, Size: 25, Number: 4101
. 2009-10-27 16:38:20.226 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2009-10-27 16:38:20.226 Type: SSH_FXP_ATTRS, Size: 37, Number: 3848
. 2009-10-27 16:38:20.226 Storing reserved response
< 2009-10-27 16:38:21.007 Status code: 4, Message: 5893, Server: Failure, Language:
. 2009-10-27 16:38:21.210 18 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-10-27 16:38:21.210 Type: SSH_FXP_CLOSE, Size: 13, Number: 6916
* 2009-10-27 16:38:21.210 (ECommand) Copying files from remote side failed.
* 2009-10-27 16:38:21.210 General failure (server should provide error description).
* 2009-10-27 16:38:21.210 Error code: 4
* 2009-10-27 16:38:21.210 Error message from server: Failure
* 2009-10-27 16:38:21.210 Request code: 5
. 2009-10-27 16:38:25.867 Closing connection.
. 2009-10-27 16:38:25.867 Sending special code: 12
. 2009-10-27 16:38:25.867 Sent EOF message
Log from FileZilla 3.2.7.1:
2009-10-27 16:59:41 4084 0 Status: Connecting to 10.10.5.15...
2009-10-27 16:59:41 4084 0 Trace: Going to execute D:\Programe\FileZillaPortable\App\filezilla\fzsftp.exe
2009-10-27 16:59:41 4084 0 Response: fzSftp started
2009-10-27 16:59:41 4084 0 Trace: CSftpControlSocket::ConnectParseResponse(fzSftp started)
2009-10-27 16:59:41 4084 0 Trace: CSftpControlSocket::SendNextCommand()
2009-10-27 16:59:41 4084 0 Trace: CSftpControlSocket::ConnectSend()
2009-10-27 16:59:41 4084 0 Command: open "user@10.10.5.15" 22
2009-10-27 16:59:41 4084 0 Trace: Looking up host "10.10.5.15"
2009-10-27 16:59:41 4084 0 Trace: Connecting to 10.10.5.15 port 22
2009-10-27 16:59:41 4084 0 Trace: Server version: SSH-2.0-1.36 sshlib: T9999G06_15Apr2008_comForte_SSH2_0079
2009-10-27 16:59:41 4084 0 Trace: Using SSH protocol version 2
2009-10-27 16:59:41 4084 0 Trace: We claim version: SSH-2.0-PuTTY_Local:_Aug_23_2009_19:56:54
2009-10-27 16:59:41 4084 0 Trace: Using Diffie-Hellman with standard group "group1"
2009-10-27 16:59:41 4084 0 Trace: Doing Diffie-Hellman key exchange with hash SHA-1
2009-10-27 16:59:42 4084 0 Trace: Host key fingerprint is:
2009-10-27 16:59:42 4084 0 Trace: ssh-dss 1024 22:a3:1e:60:52:95:11:62:be:5a:60:4c:7f:75:f5:04
2009-10-27 16:59:42 4084 0 Trace: Initialised AES-256 CBC client->server encryption
2009-10-27 16:59:42 4084 0 Trace: Initialised HMAC-SHA1 client->server MAC algorithm
2009-10-27 16:59:42 4084 0 Trace: Initialised AES-256 CBC server->client encryption
2009-10-27 16:59:42 4084 0 Trace: Initialised HMAC-SHA1 server->client MAC algorithm
2009-10-27 16:59:42 4084 0 Command: Pass: *******
2009-10-27 16:59:42 4084 0 Trace: Sent password
2009-10-27 16:59:42 4084 0 Trace: Access granted
2009-10-27 16:59:42 4084 0 Trace: Opened channel for session
2009-10-27 16:59:44 4084 0 Trace: Started a shell/command
2009-10-27 16:59:44 4084 0 Status: Connected to 10.10.5.15
2009-10-27 16:59:44 4084 0 Trace: CSftpControlSocket::ConnectParseResponse()
2009-10-27 16:59:44 4084 0 Trace: CSftpControlSocket::ResetOperation(0)
2009-10-27 16:59:44 4084 0 Trace: CControlSocket::ResetOperation(0)
2009-10-27 16:59:44 4084 0 Status: Retrieving directory listing...
2009-10-27 16:59:44 4084 0 Trace: CSftpControlSocket::SendNextCommand()
2009-10-27 16:59:44 4084 0 Trace: CSftpControlSocket::ChangeDirSend()
2009-10-27 16:59:44 4084 0 Command: pwd
2009-10-27 16:59:44 4084 0 Response: Current directory is: "/G/test00/test"
2009-10-27 16:59:44 4084 0 Trace: CSftpControlSocket::ParseSubcommandResult(0)
2009-10-27 16:59:44 4084 0 Trace: CSftpControlSocket::ListSubcommandResult()
2009-10-27 16:59:44 4084 0 Trace: CSftpControlSocket::ListSend()
2009-10-27 16:59:44 4084 0 Command: ls
2009-10-27 16:59:44 4084 0 Status: Listing directory /G/test00/test
2009-10-27 16:59:45 4084 0 Listing: -rwx------ 0 57093 223 2856 Oct 26 16:03 filetest
2009-10-27 16:59:45 4084 0 Trace: CSftpControlSocket::ListParseResponse()
2009-10-27 16:59:45 4084 0 Trace: CSftpControlSocket::SendNextCommand()
2009-10-27 16:59:45 4084 0 Trace: CSftpControlSocket::ListSend()
2009-10-27 16:59:45 4084 0 Status: Calculating timezone offset of server...
2009-10-27 16:59:45 4084 0 Command: mtime "filetest"
2009-10-27 16:59:45 4084 0 Response: 1256569421
2009-10-27 16:59:45 4084 0 Trace: CSftpControlSocket::ListParseResponse(1256569421)
2009-10-27 16:59:45 4084 0 Status: Timezone offsets: Server: 3600 seconds. Local: 7200 seconds. Difference: 3600 seconds.
2009-10-27 16:59:45 4084 0 Trace: CSftpControlSocket::ResetOperation(0)
2009-10-27 16:59:45 4084 0 Trace: CControlSocket::ResetOperation(0)
2009-10-27 16:59:45 4084 0 Status: Directory listing successful
2009-10-27 16:59:49 4084 0 Status: Retrieving directory listing...
2009-10-27 16:59:49 4084 0 Trace: CSftpControlSocket::SendNextCommand()
2009-10-27 16:59:49 4084 0 Trace: CSftpControlSocket::ChangeDirSend()
2009-10-27 16:59:49 4084 0 Command: cd ".."
2009-10-27 16:59:49 4084 0 Response: New directory is: "/G/test00"
2009-10-27 16:59:49 4084 0 Trace: CSftpControlSocket::ResetOperation(0)
2009-10-27 16:59:49 4084 0 Trace: CControlSocket::ResetOperation(0)
2009-10-27 16:59:49 4084 0 Trace: CSftpControlSocket::ParseSubcommandResult(0)
2009-10-27 16:59:49 4084 0 Trace: CSftpControlSocket::ListSubcommandResult()
2009-10-27 16:59:49 4084 0 Trace: CSftpControlSocket::ListSend()
2009-10-27 16:59:49 4084 0 Command: ls
2009-10-27 16:59:49 4084 0 Status: Listing directory /G/test00
2009-10-27 16:59:50 4084 0 Listing: drwxrwxrwx 0 65535 255 4096 Oct 27 15:59 test
2009-10-27 16:59:50 4084 0 Trace: CSftpControlSocket::ListParseResponse()
2009-10-27 16:59:50 4084 0 Trace: CSftpControlSocket::ResetOperation(0)
2009-10-27 16:59:50 4084 0 Trace: CControlSocket::ResetOperation(0)
2009-10-27 16:59:50 4084 0 Status: Directory listing successful
2009-10-27 16:59:51 4084 0 Status: Retrieving directory listing...
2009-10-27 16:59:51 4084 0 Trace: CSftpControlSocket::SendNextCommand()
2009-10-27 16:59:51 4084 0 Trace: CSftpControlSocket::ChangeDirSend()
2009-10-27 16:59:51 4084 0 Command: cd ".."
2009-10-27 16:59:51 4084 0 Response: New directory is: "/G"
2009-10-27 16:59:51 4084 0 Trace: CSftpControlSocket::ResetOperation(0)
2009-10-27 16:59:51 4084 0 Trace: CControlSocket::ResetOperation(0)
2009-10-27 16:59:51 4084 0 Trace: CSftpControlSocket::ParseSubcommandResult(0)
2009-10-27 16:59:51 4084 0 Trace: CSftpControlSocket::ListSubcommandResult()
2009-10-27 16:59:51 4084 0 Trace: CSftpControlSocket::ListSend()
2009-10-27 16:59:51 4084 0 Command: ls
2009-10-27 16:59:51 4084 0 Status: Listing directory /G
2009-10-27 16:59:53 4084 0 Listing: drwxrwxrwx 0 65535 255 4096 Oct 27 15:59 test01
2009-10-27 16:59:53 4084 0 Listing: drwxrwxrwx 0 65535 255 4096 Oct 27 15:59 test00
2009-10-27 16:59:53 4084 0 Trace: CSftpControlSocket::ListParseResponse()
2009-10-27 16:59:53 4084 0 Trace: CSftpControlSocket::ResetOperation(0)
2009-10-27 16:59:53 4084 0 Trace: CControlSocket::ResetOperation(0)
2009-10-27 16:59:53 4084 0 Status: Directory listing successful
2009-10-27 17:00:03 4084 0 Status: Retrieving directory listing...
2009-10-27 17:00:03 4084 0 Trace: CSftpControlSocket::SendNextCommand()
2009-10-27 17:00:03 4084 0 Trace: CSftpControlSocket::ChangeDirSend()
2009-10-27 17:00:03 4084 0 Command: cd "test01"
2009-10-27 17:00:04 4084 0 Response: New directory is: "/G/test01"
2009-10-27 17:00:04 4084 0 Trace: CSftpControlSocket::ResetOperation(0)
2009-10-27 17:00:04 4084 0 Trace: CControlSocket::ResetOperation(0)
2009-10-27 17:00:04 4084 0 Trace: CSftpControlSocket::ParseSubcommandResult(0)
2009-10-27 17:00:04 4084 0 Trace: CSftpControlSocket::ListSubcommandResult()
2009-10-27 17:00:04 4084 0 Trace: CSftpControlSocket::SendNextCommand()
2009-10-27 17:00:04 4084 0 Trace: CSftpControlSocket::ListSend()
2009-10-27 17:00:04 4084 0 Command: ls
2009-10-27 17:00:04 4084 0 Status: Listing directory /G/test01
2009-10-27 17:00:04 4084 0 Listing: drwxrwxrwx 0 65535 255 4096 Oct 27 16:00 test
2009-10-27 17:00:04 4084 0 Trace: CSftpControlSocket::ListParseResponse()
2009-10-27 17:00:04 4084 0 Status: Directory listing successful
2009-10-27 17:00:06 4084 0 Status: Retrieving directory listing...
2009-10-27 17:00:06 4084 0 Trace: CSftpControlSocket::SendNextCommand()
2009-10-27 17:00:06 4084 0 Trace: CSftpControlSocket::ChangeDirSend()
2009-10-27 17:00:06 4084 0 Command: cd "test"
2009-10-27 17:00:07 4084 0 Response: New directory is: "/G/test01/test"
2009-10-27 17:00:07 4084 0 Trace: CSftpControlSocket::ResetOperation(0)
2009-10-27 17:00:07 4084 0 Trace: CControlSocket::ResetOperation(0)
2009-10-27 17:00:07 4084 0 Trace: CSftpControlSocket::ParseSubcommandResult(0)
2009-10-27 17:00:07 4084 0 Trace: CSftpControlSocket::ListSubcommandResult()
2009-10-27 17:00:07 4084 0 Trace: CSftpControlSocket::SendNextCommand()
2009-10-27 17:00:07 4084 0 Trace: CSftpControlSocket::ListSend()
2009-10-27 17:00:07 4084 0 Command: ls
2009-10-27 17:00:07 4084 0 Status: Listing directory /G/test01/test
2009-10-27 17:00:09 4084 0 Listing: -rwx------ 0 57343 223 6439680 Oct 27 02:02 file
2009-10-27 17:00:09 4084 0 Trace: CSftpControlSocket::ListParseResponse()
2009-10-27 17:00:09 4084 0 Trace: CSftpControlSocket::ResetOperation(0)
2009-10-27 17:00:09 4084 0 Trace: CControlSocket::ResetOperation(0)
2009-10-27 17:00:09 4084 0 Status: Directory listing successful
2009-10-27 17:00:20 4084 1 Status: Connecting to 10.10.5.15...
2009-10-27 17:00:20 4084 1 Trace: Going to execute D:\Programe\FileZillaPortable\App\filezilla\fzsftp.exe
2009-10-27 17:00:20 4084 1 Response: fzSftp started
2009-10-27 17:00:20 4084 1 Trace: CSftpControlSocket::ConnectParseResponse(fzSftp started)
2009-10-27 17:00:20 4084 1 Trace: CSftpControlSocket::SendNextCommand()
2009-10-27 17:00:20 4084 1 Trace: CSftpControlSocket::ConnectSend()
2009-10-27 17:00:20 4084 1 Command: open "user@10.10.5.15" 22
2009-10-27 17:00:20 4084 1 Trace: Looking up host "10.10.5.15"
2009-10-27 17:00:20 4084 1 Trace: Connecting to 10.10.5.15 port 22
2009-10-27 17:00:21 4084 1 Trace: Server version: SSH-2.0-1.36 sshlib: T9999G06_15Apr2008_comForte_SSH2_0079
2009-10-27 17:00:21 4084 1 Trace: Using SSH protocol version 2
2009-10-27 17:00:21 4084 1 Trace: We claim version: SSH-2.0-PuTTY_Local:_Aug_23_2009_19:56:54
2009-10-27 17:00:21 4084 1 Trace: Using Diffie-Hellman with standard group "group1"
2009-10-27 17:00:21 4084 1 Trace: Doing Diffie-Hellman key exchange with hash SHA-1
2009-10-27 17:00:21 4084 1 Trace: Host key fingerprint is:
2009-10-27 17:00:21 4084 1 Trace: ssh-dss 1024 22:a3:1e:60:52:95:11:62:be:5a:60:4c:7f:75:f5:04
2009-10-27 17:00:21 4084 1 Trace: Initialised AES-256 CBC client->server encryption
2009-10-27 17:00:21 4084 1 Trace: Initialised HMAC-SHA1 client->server MAC algorithm
2009-10-27 17:00:21 4084 1 Trace: Initialised AES-256 CBC server->client encryption
2009-10-27 17:00:21 4084 1 Trace: Initialised HMAC-SHA1 server->client MAC algorithm
2009-10-27 17:00:21 4084 1 Command: Pass: *******
2009-10-27 17:00:21 4084 1 Trace: Sent password
2009-10-27 17:00:22 4084 1 Trace: Access granted
2009-10-27 17:00:22 4084 1 Trace: Opened channel for session
2009-10-27 17:00:24 4084 1 Trace: Started a shell/command
2009-10-27 17:00:24 4084 1 Status: Connected to 10.10.5.15
2009-10-27 17:00:24 4084 1 Trace: CSftpControlSocket::ConnectParseResponse()
2009-10-27 17:00:24 4084 1 Trace: CSftpControlSocket::ResetOperation(0)
2009-10-27 17:00:24 4084 1 Trace: CControlSocket::ResetOperation(0)
2009-10-27 17:00:24 4084 1 Trace: CSftpControlSocket::FileTransfer(...)
2009-10-27 17:00:24 4084 1 Status: Starting download of /G/test01/test.file
2009-10-27 17:00:24 4084 1 Trace: CSftpControlSocket::SendNextCommand()
2009-10-27 17:00:24 4084 1 Trace: CSftpControlSocket::ChangeDirSend()
2009-10-27 17:00:24 4084 1 Command: cd "/G/test01/test"
2009-10-27 17:00:24 4084 1 Response: New directory is: "/G/test01/test"
2009-10-27 17:00:24 4084 1 Trace: CSftpControlSocket::ParseSubcommandResult(0)
2009-10-27 17:00:24 4084 1 Trace: CSftpControlSocket::FileTransferSubcommandResult()
2009-10-27 17:00:24 4084 1 Trace: FileTransferSend()
2009-10-27 17:00:24 4084 1 Command: get "file" "D:\file"
2009-10-27 17:00:25 4084 1 Status: remote:/G/test01/test/file => local:D:\file
2009-10-27 17:01:11 4084 1 Trace: FileTransferParseResponse()
2009-10-27 17:01:11 4084 1 Trace: CSftpControlSocket::ResetOperation(0)
2009-10-27 17:01:11 4084 1 Trace: CControlSocket::ResetOperation(0)
2009-10-27 17:01:11 4084 1 Status: File transfer successful
2009-10-27 17:01:14 4084 1 Trace: CSftpControlSocket::ResetOperation(66)
2009-10-27 17:01:14 4084 1 Trace: CControlSocket::ResetOperation(66)
2009-10-27 17:01:14 4084 0 Trace: CSftpControlSocket::ResetOperation(66)
2009-10-27 17:01:14 4084 0 Trace: CControlSocket::ResetOperation(66)
Re: download files from tandem OS
It is hard to help you as the server does not indicate any reason why it fails. Can you see anything useful in the server's log file?
Unfortunately I don't have access to server log.
As i know, winscp is based on filezilla engine, why in filezilla everithing is working and here not ?
It is a different SFTP protocol, version or what ?
I cannot see SFTP verion in filezilla :|.
Regards,
G.
WinSCP uses only FTP code from Filezilla, not SFTP.
No. Filezilla knows only version 3.
In FileZilla,I can select the type of the SFTP server, and I select HpNonStop.
Can I select these from WinSCP somehow ?
As I say previous, if I transfer an ascii file, this can be done, but if I transfer a binary file I receive an error.
It is something with the SFTP protocol that is used by HPNonStop SO.
Actually, when the transfer starts, 40KB are transfer, and then O receive the error.
I think that SFTP server from HP NonStop mainframe wants to verify if the transfer is OK.
Also, the ASCII file is not transfer with CRLF end of line, even if I select ASCII file type when transfer start.
There's no point selecting this with SFTP. In Filezilla the option affects how it parses directory listing and interprets the file path format. It is important with FTP protocol as it does not enforce any standards on the formats. But SFTP does. WinSCP adheres to the standards. I'm not even sure that Filezilla takes the option into account with SFTP. And if it does, it is wrong.
What kind of verification do you mean?
Since the transfer start, and a part of the files is transferred, maybe the problem is with a file check (checksum of the file part transferred).
We got a similar problem with WS_FTP 12, and with the new version the problem was solve.
I ask them what is the cause, but the only answer was that the problem is fixed and I should move to the new version.
Regards,
G.
I try to make the same download from PSFTP, and is working fine.
I try also with WinSCP 4.2.5 but I receive the same error.
It downloads a part of the file (40,948 bytes), when I try again to download the file, it ask me if I want to resume the transfer, and download anothe pice of 40,948 bytes.
It is very strange.
It is very strange.
Please post a full log file showing the problem. Start a new topic for that.
Sanjay
I had faced while uploading a file in Xen server using winscp due to space u have to copy a files in /var/run/sr-mount/55ff0e01-d851-6b80-2a01-24b793b8fbb0/ directory.
Error code: 4
Request code: 14
--Scott
kishore ghag
Error code 4
I had also same issue. I was getting the error while copying the file over WInscp. getting Error code 4.
I have changed default protocol rom SFTP to SCP and then it worked .
ajit.iyer
WINSCP ERROR
HI ,
I am getting this below error. Please help me.
Error code: 4
Request code: 18
(A)bort, (R)etry, (S)kip, Ski(p) all:
[/quote]
Re: WINSCP ERROR
Error code: 4
Request code: 18
See documentation for possible reasons you may be getting the error.
user123fromindia
Thanks Rafi. I faced the same issue. After deleting non essential files, the issue was resolved.
Good luck!
Chandra Mauli Singh
Re: Error code 4
kishore ghag wrote:
I had also same issue. I was getting the error while copying the file over WinSCP. was getting Error code 4.
I have changed default protocol from SFTP to SCP and then it worked .
I changed default protocol from SFTP to SCP. it worked.
t.venkib8@...
copying files to remote side failed General failure
When i'm trying to copy file from Local to server, it is throwing below error:
copying files to remote side failed General failure (server should provide error description). Error code: 4 Error message from server: Failure
Re: copying files to remote side failed General failure
Please start a new thread and attach a full session log file showing the problem (using the latest version of WinSCP).
Re: When you edit and then save it is an error
George_jorge wrote:
Unable to overwrite file '/usr/local/fop2/buttons.cfg'
Press the 'Delete' button to delete the file and try again to overwrite it
General error (The server must have provided more information)
Error Code: 4
Please start a new thread and post a complete English session log file.
This helped. Thanks!
Good luck!
Chedimorchdi
Re: error code 4 (server failure Hello, how did you solve it ? Do I need to just delete files ?
Good luck!
