feature request
Onanymous
feature request
I am afraid it is already there but if not is it possible to incorporate the autocomplete, cause it is present in original putty, maybe one could turn on the 'tab' autocomplete when the command line is not empty.
Home directory ctrl+\ is not working properly, it gets me somewhere deep.
I have the ssh access to comp_1 from which I can access the comp_2 via ssh (but not directly, due to ip restrictions), is it possible to create the transparent access to comp_2 via comp_1 using winscp with complete or almost complete functionality?
Re: feature request
Putty does not have autocomplete. It is AFAIK nonsense. Putty is just terminal, it has no idea about files at all.
However I'll consider your request.
Ctrl+\ does not change to home directory. It changes to root directory.
It should be possible, but I have never done it. Please search the forum. You'll find some hints from other users.
Onanymous
Re: feature request
Sorry for my veeery inaccurate post, you must be extremely tolerant person.
Yes sure I just meant... well you know what I meant.
Oops, that is true :) is there a shortcut to change to a home directory in winscp?
And I forgot to say my thanks for yours great plugin. thanks.
Re: feature request
I'm afraid that not :-( I'll add some.
