Integral Editor
Adem
Integral Editor
Ok, this is not exactly a bug, but a vey unexpected behavior all the same.
When I do a search in the integral editor, and if the text is not found, it *sometimes* hides the editor and displays the parent WinSCP instance with the find dialog over it.
Now, this is something it does sometimes; it is repeatable but not deterministically.
Another one is, when you click any of the toolbar buttons in the integral editor, similar to the find dialog, parent WinSCP instance is shown.
It seems to me that these are artifacts from the days when the editor was a modal window.
Just one more thing: Could we have a properties button for the integral editor so that we can see all sorts of info (editor's own version, file name & name, server info etc).
Thank you for this beatiful work.
Best Regards,
Adem
Re: Integral Editor
I know about this problem, but I was not yet able to find why it happens. I'll try again :-)
What do you mean by 'editor's own version' and 'file name & name'?
Re: Integral Editor
One of these days, you may want to follow two separate development for the editor, that is why I said 'editor's own version'. If not, just ignore that.
Apparently, i am typing faster than my eyes:
'file name & name' should have been 'file path and name', or just 'fully qualified file path'
Sorry.
