Copy To Clipboard as Name
Adem
MS Windows Poer tools have a Context Menu extension named 'Sendto Clipboard As Name' which copies the path of a file to clipboard.
This is very useful if you need that files full path information (i.e. including its name).
Could you add something like that to WinSCP, please.
Actually, I would like 2 items added to the popup menu:
i) Copy Path to Clipboard
Copies only local path information; i.e.
/etc/somefile.conf
ii) Copy Full Path to Clipboard
Copies fully qualified information; i.e.
scp://user:password@myserver.com/etc/somefile.conf
Cheers,
Adem
Re: Copy To Clipboard as Name
/etc/somefile.conf
File(s) > File names > Copy to clipboard
I may add this. Meanwhile, you may find this topic useful.
Can you not place this into the context menu.
That thread is not much to do with what I am asking for. All I want is the FQDN.
I am not bothered whether WinSCP supports the URL protocol.
Maybe.
I guess it has. The thread solves much more complicated problem. Your problem is just subset of it.
I do not understand this point.
