buttons defaced
j.r.allington-smith@durha
buttons defaced
Often when I start WinSCP the buttons at the top are defaced and are replaced by a meaningless blur. Only the buttons are affected - everything else looks okay. The problem is cured only by rebooting and seems to be especially likely to occur after starting any version of Netscape. I am using Windows 98. Thanks for writing the software!
If my username is incomplete it is because further letters are not echoed - is there a limit to the number of characters?
Re: buttons defaced
I guess that this is well known problem of application developed with Borland tools running on machine with certain types of graphics cards (like S3). I'm afraid that I can't do anything with this.
