Compression
ralfhauser
I have enabled compression in the ssh login panel, but the zip-icon at the bottom of my winscp window is still red-crossed.
How can I get this working?
Ralf
P.S.: When double-clicking on the zip-icon, I see the following
SSH protocol version = SSH-2
SSH implementation = OpenSSH_4.3p2 Debian-5ubuntu1
Encryption algorithm = aes
Compression = No
File transfer protocol = SFTP (v3)
Additional protocol information
The server does not support any SFTP extension.
Reply with quote E-mail
hramrach
dealyed compression not supported
For some reason wiscp does not enable compression if the compression is set to "delayed" in openssh (the default). IF set to "yes" compression works.
Rabie van der Merwe
Re: dealyed compression not supported
Any chance WinSCP will support delayed compression at a later stage?
It would be nice seeing as that is the default in most sshd deployments. :)
It would be nice seeing as that is the default in most sshd deployments. :)[/quote]
Once it is implemented in PuTTY... :-)
This issue has been added to tracker.
