Install winscp 3.7 on winxp servicepack 2
Bert F.
When I try to run winscp370setup.exe I always get
the error message "The NTVDM-CPU has found a bad command"
I'm using Win XP Professional with Servicepack 2,
language German.
Re: Install winscp 3.7 on winxp servicepack 2
Only think I can recommend you is to download the file again. You may try to verify checksum of the donwloaded file (MD5).
Bert F.
Thanks, using another mirror, I succeeded.
