Double Click -> Command
Double-Click use operation to perform to select what should WinSCP do when you double-click file in file panel:
Open - open file.
Copy - transfer file (upload or download).
Edit (default) - edit file.
Please, can you add COMMAND in the list like:
Open - open file.
Command *new
Example: Double-click -> echo "winner: " >> !
With this option the user can use explorer interface with very power usability.
Re: Double Click -> Command
Thanks for your suggestion.
Will see if more people ask for this.
Btw, Do you know that you can assign a keyboard shortcut to the custom command?
