Ooh ooh, stupid me, but read 2nd post anyway...
duerra
If there is ever time, it would be really wonderful to be able to have a tabbed interface for being able to keep multiple directories open simultaneously. Unfortunately, I often find myself with 3 or even more copies of WinSCP open so that I can quickly look at a few different directories. Unfortunately, it's not very economical to add all different working directories to your bookmarks for directories that you want to keep open temporarily.
I wouldn't think this to be too difficult to integrate into WinSCP, but unfortunately, I develop in a spoiled world where such things are pretty much already programmed for you (.NET) =/
PS - prikyl, when you get a second, could you quickly add a "New Folder" option to the right-click menus?
You do a fantastic job with WinSCP. I'm incredibly impressed with the work you've done to bring it where it is today. Great job.
Thanks =)
_________________
When you put everything into something, it means everything to you.
duerra
Ooh Ooh Ooh! I see the dropdown menu thingy now!
n/m the whole tab thing. You already have a workable solution to the multiple-instances issue.
HOWEVER....
-- Could you make that session-selected dropdown resizable like you make the path textboxes? =)
-- it would still be nice to have that new-folder right click menu item.
Thanks! =)
_________________
I'll try. But I do not promise :-)
Hmm, It seems like reasonable request :-)
