Issue With WINSCP GUI
scroft
Using WINSCP Version 5.7.5 (Build 5665)
I am launching WINSCP from a Windows Server 2008 R2 Standard.
I am using SFTP to connect to a Linux Server.
I am able to connect and see the remote file system directories on my Linux server, but my Local directories are not being shown?
I have another Windows Server in a different domain and everything works as it should when connecting to a similar windows server.
On my good instance, I see these items on the Toolbar...
Local - Mark - Files - Commands - Session - Options - Remote - Help
On the instance I am having issues with I only see these items on the Toolbar...
File - Commands - Mark - Session - View - Help
I have tried both Explorer and Commander interfaces and tried to set the local directory, but I am having no luck.
Any help would be greatly appreciated
Re: Issue With WINSCP GUI
Where if your local "Documents" folder located?
Can you navigate to another folder using Drives drop down or Open Directory command?
