possible "session password" bug - but i need help with passwords anyway
stgmike
seattle, washington
I noticed there is a thread regarding this exact issue from mid 2003 form an old version of WinSCP, but the apparent fix back then was an update to the PuTTY libs - you are now using newer libs than then, so maybe their problem is back?
I am entering a domain (ftp.seattletech.com) and a user (mike) and the appropriate password (this login/pw works when using regular FTP in IE and DOS, for example). WinSCP gets to the authenticating stage, then asks for the session password for "mike@ftp.seattletech.com". Any password I try here fails with the following error:
Using username "mike".
Access denied
Access denied
Server sent disconnect message
type 2 (SSH_DISCONNECT_PROTOCOL_ERROR):
"Too many authentication failures for mike"
I don't have an email account for mike@ftp.seattletech.com, but I *do* have one for mike@seattletech.com. If I enter "mike@seattletech.com" for the login, WinSCP asks for the session password for "mike@seattletech.com@ftp.seattletech.com"
How can I enter an email address as a login (an email address with a different domain that the one I'm logging into)? And why is this session password problem happening (again?)?
I am running Win2K SP4, WinSCP3.68 and 3.7, trying to log into my shared host's FTP (Redhat linux 2.4.25, Apache 1.3.31.
Here is a snippet from the WinSCP log:
. WinSCP Version 3.7.0 (Build 254) (OS 5.0.2195 Service Pack 4)
. Login time: Friday, October 22, 2004 4:43:54 PM
. Session name: mike@ftp.seattletech.com
. Host name: ftp.seattletech.com (Port: 22)
. User name: mike (Password: Yes, Key file: No)
. Transfer Protocol: SFTP (SCP)
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Local directory: default, Remote directory: home, Update: No, Cache: Yes
. Cache directory changes: Yes, Permanent: Yes
. Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. Looking up host "ftp.seattletech.com"
. Connecting to 65.98.117.87 port 22
. Server version: SSH-1.99-OpenSSH_3.1p1
. We believe remote version has SSH2 RSA padding bug
. We claim version: SSH-2.0-WinSCP-release-3.7
. Host key fingerprint is:
. ssh-rsa 1024 ff:19:cb:73:83:ac:bc:03:e3:1c:89:77:e3:4b:cb:4b
. Initialised HMAC-SHA1 client->server MAC algorithm
. Initialised HMAC-SHA1 server->client MAC algorithm
! Using username "mike".
. Keyboard-interactive authentication refused
. Session password prompt (mike@ftp.seattletech.com's password: )
. Using stored password.
. Sent password
! Access denied
. Access denied
. Asking user for password.
. Sent password
! Access denied
. Access denied
. Received disconnect message (SSH_DISCONNECT_PROTOCOL_ERROR)
. Disconnection message text: Too many authentication failures for mike
. Server sent disconnect message
. type 2 (SSH_DISCONNECT_PROTOCOL_ERROR):
. "Too many authentication failures for mike"
* (ESshFatal) Authentication failed.
* Authentication log (see session log for details):
* Using username "mike".
* Access denied
* Access denied
* Server sent disconnect message
* type 2 (SSH_DISCONNECT_PROTOCOL_ERROR):
* "Too many authentication failures for mike"
What else do you need to know? I can provide you with the password for the "mike" account I've mentioned in this message.
Thanks!
- Mike
Re: possible "session password" bug - but i need help with passwords anyway
I'll try to reproduce the problem. If I do not succeed, I'll contact you.
While I do not have any server with @ in usernames, it would guess that it should work. If I enter xxx@xxx as username I can see in the log message
! Using username "xxx@xxx".
And I'm prompted for session password for 'xxx@xxx@host'. This is all correct.
I may not understand your problem. Is you username really your email address or it is just your guess?
Are you sure you have access to the SSH server on ftp.seattletech.com?
stgmike
seattle, washington
Unfortunately, I'm working with a shared host. I do have SSH access - I can log in with our master account. But, while I'm allowed to create additional FTP accounts, they don't work with SSH. I thought it might be a problem with WinSCP because the 'xxx@xxx@host' confused me - now I understand it. Sorry to bother you, and thanks for taking your tim to try to figure it out. It most likely is a problem of my host not allowing my additional FTP accounts access via SSH.
- Mike
Dave Kappel
Too Many Authenications Failures
I also am receiving this error, it appears to re-occur with any new user I have added after initial installation. Any help would be greatly appreciated.
Here is a copy of the last user I attempted. Help...Thanks Dave
. WinSCP Version 3.7.0 (Build 254) (OS 5.1.2600 Service Pack 1)
. Login time: Monday, November 01, 2004 9:16:38 AM
. Session name: Angi@68.143.37.74
. Host name: 68.143.37.74 (Port: 22)
. User name: Angi (Password: Yes, Key file: No)
. Proxy: none
. Looking up host "68.143.37.74"
. Connecting to 68.143.37.74 port 22
. Server version: SSH-1.99-OpenSSH_3.9p1
. ssh-rsa 1024 fc:62:01:31:d5:f3:c1:45:10:9b:86:0c:88:bd:f3:20
! Using username "Angi".
. Session password prompt (Angi@68.143.37.74's password: )
. Sent password
! Access denied
. Access denied
. Sent password
! Access denied
. Access denied
. Disconnection message text: Too many authentication failures for Angi
. "Too many authentication failures for Angi"
* Using username "Angi".
* Access denied
* Access denied
* "Too many authentication failures for Angi"
. Login time: Monday, November 01, 2004 9:19:14 AM
. Session name: prnfs\Angi@68.143.37.74
. User name: prnfs\Angi (Password: Yes, Key file: No)
. Proxy: none
! Using username "prnfs\Angi".
. Session password prompt (prnfs\Angi@68.143.37.74's password: )
. Sent password
! Access denied
. Access denied
. Sent password
! Access denied
. Access denied
. Disconnection message text: Too many authentication failures for prnfs\Angi
. "Too many authentication failures for prnfs\Angi"
* Using username "prnfs\Angi".
* Access denied
* Access denied
* "Too many authentication failures for prnfs\Angi"
Re: Too Many Authenications Failures
I do not see any similarity of your problem to the one above. Can you explain this? All I can see is that you are unable to login. That's what I can hardly help you with. You should beter ask your server administrator. Or check the server log file if you are one.
