billprew Joined: 2004-10-19 Posts: 2 Saving copies of changed files during sync 2004-10-20 20:38 Is there any way to save a copy of the replaced file when I use the synchronize comand? I'd like to be able to archive off any deleted or updated files during the sync process, so I know that they looked like before. Reply with quote
martin◆ Site Admin Joined: 2002-12-10 Posts: 43,049 Location: Prague, Czechia Re: Saving copies of changed files during sync 2004-10-21 In what direction do you perform the synchronisation? If local->remote, you may use remote recycle bin feature. See Environment tab of Login dialog. If remote->local, deleted files can be moved to recycle bin as well. Overwritten files cannot be preserved. Reply with quote
