GetFiles Method Has Started Attempting to Delete Remote Directory
tmiddleton
Tulsa
We started getting permission denied exceptions out of nowhere the other night. It's coming from the remote server when we try to remove the remote files after downloading. We are using GetFiles method with the Remove flag set to true. There were no code changes on our end that I know of and at the time of first occurance we were running 5.7.1. I found a similar bug report and upgraded to 5.7.5 but the behavior has not changed. Is there a way to disable this behavior? I only want the files removed not the folder.
I apologize in advance if this this is already covered somewhere but I could find no other reference to this behavior nor any property I could set to turn it off.
I've attached the relevant portion of the log.
Reply with quote E-mail
Re: GetFiles Method Has Started Attempting to Delete Remote Directory
What "this behaviour"?
Show us your code and the session log file (Session.SessionLogPath).
tmiddleton
Tulsa
Hello, thank you for responding so quickly!
The behavior or action I want it to take is to delete the remote files that were successfully downloaded but not the remote directory. The login being used doesn't have sufficient privileges to remove a directory so the permission denied exception is being returned and causing the script to terminate with a failure code.
I've included the script below. The log I attached in the fist post is from the session log file. I'll get you a more complete version if needed asap.
$CurrentDir = Split-Path ((Get-Variable MyInvocation -Scope 0).Value).MyCommand.Path
$ProcessingFolder = "\\local\path\"
try
    $sessionOptions.HostName = ""
    $sessionOptions.UserName = ""
    $sessionOptions.Password =
    $sessionOptions.SshHostKeyFingerprint = ""
    $sessionOptions.Timeout = New-TimeSpan -Seconds 30
    $session.SessionLogPath = "$CurrentDir\WinSCP.log"
    $transferOptions.TransferMode = [WinSCP.TransferMode]::Automatic
    $transferOptions.FilePermissions = $null
    $transferOptions.PreserveTimestamp = $False
    $transferResult = $session.GetFiles("/remote/path/", $ProcessingFolder, $True, $transferOptions)
    $transferResult.Check()
catch [Exception]
    ...Send Email...
    exit 1
finally
    # Disconnect, clean up
    $session.Dispose()
So download (and delete) the files only, not the parent directory:
$transferResult = $session.GetFiles("/remote/path/*", $ProcessingFolder, $True, $transferOptions)
MarkovdWeide
Re: Exception with GetFiles() with Remove on Directory
I'd like to add something I encountered using this 'trick' real quick. Using the asterisk (*) does indeed preserve the directory on the remote server. However, I needed to use the asterisk in both the remotePath and localPath! Without an asterisk in the localPath the transfer failed stating that the localPath was "not a file!"
$transferResult = $session.GetFiles("/remote/path/*", "local/path/*", $True, $transferOptions)
You do not need the asterisk, but you do need the trailing backslash: "local/path/".
