Recursive get and delete files (but not the directories !)
lennelei
France
I have a FTP server with the following directories:
/OUT/DIR1/
/OUT/DIR2/
/OUT/DIR3/
Within each directory, I may have one or more file named FILExxxxxxx.txt.
I wanted to write a WinSCP command to retrieve all files and then delete them, but without trying to delete the directories.
I first tried with this:
WinSCP.com /command "option batch abort" "option confirm off" "open SESSION" "cd /OUT/" "get -transfer=binary -delete -filemask=FILE*.txt * .\" "close" "exit"
If I don't use -delete option, it works, however, with the -delete option, it fails as it try to delete /OUT/DIR1 (and the user has no right for this hopefully).
I then tried with multiple filemask combination without success:
WinSCP.com /command "option batch abort" "option confirm off" "open SESSION" "cd /OUT/" "get -transfer=binary -delete -filemask=/OUT/*/FILE*.txt * .\" "close" "exit"
WinSCP.com /command "option batch abort" "option confirm off" "open SESSION" "cd /OUT/" "get -transfer=binary -delete -filemask=FILE*.txt;/OUT/*/ *" "close" "exit"
WinSCP.com /command "option batch abort" "option confirm off" "open SESSION" "cd /OUT/" "get -transfer=binary -delete -filemask=/OUT/*/FILE*.txt *" "close" "exit"
WinSCP always tries to remove directories :(
Any way to achieve this? I've seen in an old post that recursive delete was not supported by WinSCP in 2012:
Automatic delete files or folders matching a search term
but maybe today... ? :D
Thanks!
Re: Recursive get and delete files (but not the directories !)
This should work:
WinSCP.com /command "open SESSION" "get -transfer=binary -delete -filemask=/OUT/DIR1/FILE*.txt .\DIR1\" "exit"
WinSCP.com /command "open SESSION" "get -transfer=binary -delete -filemask=/OUT/DIR2/FILE*.txt .\DIR2\" "exit"
WinSCP.com /command "open SESSION" "get -transfer=binary -delete -filemask=/OUT/DIR3/FILE*.txt .\DIR3\" "exit"
lennelei
France
thank you for the suggestion, actually, I wanted to avoid having to declare each directories as they might be subject to change.
I manage to make it work by using option batch continue instead, but it's not very nice ;)
Too bad that the delete option doesn't use the filemask as well! Maybe it could be a new feature?
Thanks again.
Regards.
Alexis
