Error listing directory
shpeka
Try to login a specific FTP-server. WinSCP cannot obtain current remote directory from
remote FTP-server. The log file attached to this message.
Description: debug log from WinSCP
Re: Error listing directory
The only allowed positive response code to PWD command is 257. Your server violates the specification by using a code 250.
PWD
250 "/" is the current directory.
See RFC 959:
Essentially because the PWD command returns the same type of
information as the successful MKD command, the successful PWD
command uses the 257 reply code as well.
shpeka
So, maybe do just some option for this case and do not drop connection after received response code 250 and send
CWD / command as do other FTP clients?
