Disallow SCP fallback via API
Thusitha
I'm using winscp.exe and the API to upload files.
I'm using SFTP and I'm unable to upload files to one of mySFTP servers.
However, I'm able to upload to the same server when 'Allow SCP fallback' option is unchecked.
Is there any way to set this option using the API, so I hope my file upload would work?
Re: Disallow SCP fallback via API
This is for winscp 5.5.5
thusithagh
WinSCP version 5.5.5
ByteMyzer
Your duplicate (and answered) post on Stack Overflow:
https://stackoverflow.com/q/32991278/850848
The answer on stackoverflow is false. The WinSCP .NET assembly behaves like the "Allow SCP fallback" is checked, by default. The option must be "unchecked" with the following additional line of code:
sessionOptions.AddRawSettings("FSProtocol", "2"); // SFTPOnly
No, it's not false. If you have a different experience, please post your code and a matching log file.
