Raspberry Openelec, can't move files from SD to HDD
gerko
hello guys, after doing my WGET fileadress, I want to move that file inside my HDD, unfortunatly it does not work.
Moving file "Pi.ico" to "/var/media/RASPHDD/Pi.ico".
Type: SSH_FXP_RENAME, Size: 53, Number: 139794
Type: SSH_FXP_STATUS, Size: 24, Number: 139794
Status code: 4, Message: 139794, Server: Failure, Language:
Asking user:
Erreur durant le déplacement de 'Pi.ico' vers '/var/media/RASPHDD/Pi.ico'. ("Erreur générale
Code d'erreur : 4
Message d'erreur du serveur  : Failure")
Re: Raspberry Openelec, can't move files from SD to HDD
You generally cannot move files between file systems.
Try to copy (duplicate) and remove the original afterwards.
Gerko
Thanks ! Okay so I'll never be able move from the SD card to the HDD If I understand ?
Can I wget fileadress filedirectory ??
I do not understand what you mean.
