Change timestamp when syncing
zzgao
Hi there
Is it possible to change the timestamp of files on the remote server before syncing to 'todays' date when syncing with winscp.com and scripts?
Current script is very simple:
synchronize local "C:\user\C\V P" "/"
When the files are transferred, I want them to have todays date on the local machine
Re: Change timestamp when syncing
That won't be synchronization anymore.
Anyway, you can achieve this using:
get -neweronly -nopreservetime "/*" "C:\user\C\V P\"
