Executing winscp as a process task in ssis. task executes nor error but files are not brought down
bobghw
as title says task executes but no files brought down.
using
option batch abort
open sftp:xxxxxx:*xxxxxxx@10.xxx.xxx.xxx :22
get /Pickup Linkage files from MoH/*.txt C:\Test
the hostname, username and password are correct as tested in filezilla
the execute process task in ssis
Executable C:\Program Files (x86)\WinSCP\WinSCP.exe
Arguments -script=C:\WinscpLINKScript.txt
Working Dir C:\Program Files (x86)\WinSCP
bobghw
edit
I found some spaces in my script and sorted those, and changed the .exe to .com
and tested in cmd window.
I now get error below but "XXXXX_NHI_Link" is not the host it is the user
batch abort
reconnecttime 120
confirm off
Searching for host...
Host "XXXXX_NHI_Link" does not exist.
open sftp://XXXXX_NHI_Link:xxxxxx@10.xx.xxx.xxx:22
Re: Executing winscp as a process task in ssis. task executes nor error but files are not brought down
