unable to retrieve files using WinSCP and SSIS script
markse
New Zealand
am using SSIS script and WinSCP to get files from remote server
i can download the files using the WinSCP EXE
but fails when i try and download using SSIS script
Get
"File or foilder '\' does not exist"
connection is to an FTPES site
  • WinSCP Extract Issue 20150917.zip (170.34 KB, Private file)
Description: screen shots of WinSCP download and SSIS error
Re: unable to retrieve files using WinSCP and SSIS script
markse
New Zealand
Output log files attached
thx for the reply
we are getting ZIP files from two different locations
(with slightly different configurations)
i have attached 3 log files
first one (WinSCP_LogOutput.log) is output from site we are unable to get files from
second one (WinSCP_LogOutput_TDHB.log) is output from site which we can get files from
third one - is from LogWindows using WinSCP.exe to copy a file across successfully from the "BAD" site...
(unfortuntely can't currently use latest version of WinSCP for this (server updates take bit more time !!!) :o - hopefull ok information here)
  • Log_From_WinSCP_exe.txt (5.04 KB, Private file)
Description: third log - from WinSCP exe manual transfer
  • WinSCP_LogOutput_TDHB.log (39.47 KB, Private file)
Description: second output log - from successfull transfer
  • WinSCP_LogOutput.log (12.07 KB, Private file)
Description: first output log - from un-successul transfer
