WINSCP , wine and sublime Text
myalban
I really love WINSCP and it's clearly the best for me.
Now I'm on MAC and I can't find better than it.
So I use it with wine and it works perfectly
But I got some trouble when I try to edit a file with external editor : Sublime text.
When I save the file, it was not uploaded to the server.
File is updated on the temp folder :
MacBook-Pro:brindos alban$ ls -l
total 24
-rw-r--r--  1 alban  staff  10025 19 sep 22:41 brindos.css
total 24
-rw-r--r--  1 alban  staff  10027 20 sep 16:53 brindos.css
but never uploaded.
To load external editor and because I need to rewrite the path to be unix compatible, I use this bash script :
#!/bin/sh
path="`wine winepath -u "$1"`"
"`/Applications/Sublime\ Text.app/Contents/SharedSupport/bin/subl -w "$path"`"
exit 1
It works perfectly.
File is correctly opened in sublime text and saved....but WINSCP never upload it.
I know you don't support MAC but I really want to use it.
So if you can help me to solve this issue....
best regards
myalban
Re: WINSCP , wine and sublime Text
In fact it works fine if I use the internal editor but only fail to automatically upload if I use external editor with the bash script.
I think the bash script is the reason of this failure but I don't know how to do without.
Blacky
Romania
Same issue
I am also using WinSCP on OSX via Wine.
I am using notepad++ as an external editor also via Wine.
Everything works great except for the automatic upload. I wish this could be fixed.
Thank you!
Re: Same issue
wulltd
Hello! Has there been any progress?
I am facing the same problem. I could try out your beta app and see if I get results.
Dag
chris88g4
Mac wine and winscp
Hello , i am having the same problem, i am using Wine and notepad++. I successfully configured the winscp to open the notepad++ when i edit something but, when i save the changes never being uploaded on the remote server. If i choose internal editor from the winscp is working perfectly.
Is there any suggestion please?
Re: Mac wine and winscp
I believe we are already discussing this over an email.
