Unable to upload or download files
WinSCP 5.7.5 FTPS
Connects to server, allows to list, delete files, but any attempt to download or upload a file faile with:
. 2015-09-08 21:25:14.804 Using TLSv1, cipher TLSv1/SSLv3: RC4-SHA, 2048 bit RSA
. 2015-09-08 21:25:14.804 TLS connection established. Waiting for welcome message...
< 2015-09-08 21:25:14.804 220-Idea FTP Server v0.80 (serwer1570912.home.pl) [79.96.115.79]
< 2015-09-08 21:25:14.804 220 Ready
> 2015-09-08 21:25:15.509 SYST
< 2015-09-08 21:25:15.523 215 UNIX Type: L8
> 2015-09-08 21:25:15.523 FEAT
< 2015-09-08 21:25:15.533 211-Extensions supported
< 2015-09-08 21:25:15.533     AUTH TLS
< 2015-09-08 21:25:15.534     MDTM
< 2015-09-08 21:25:15.534     MFF Modify;UNIX.mode;
< 2015-09-08 21:25:15.534     MFMT
< 2015-09-08 21:25:15.534     MLST Type*;Size*;Modify*;Create*;Perm*;Unique*;UNIX.mode*;
< 2015-09-08 21:25:15.534     PBSZ
< 2015-09-08 21:25:15.534     PROT
< 2015-09-08 21:25:15.534     REST STREAM
< 2015-09-08 21:25:15.534     SIZE
< 2015-09-08 21:25:15.534     UTF8
< 2015-09-08 21:25:15.534 211 END
> 2015-09-08 21:25:15.535 OPTS UTF8 ON
< 2015-09-08 21:25:15.548 200 OPTS command successful.
> 2015-09-08 21:25:15.548 PBSZ 0
< 2015-09-08 21:25:15.561 200 Buffer size set to 0
> 2015-09-08 21:25:15.561 PROT P
< 2015-09-08 21:25:15.572 200 Protection level set to P
. 2015-09-08 21:25:15.572 Connected
. 2015-09-08 21:25:15.572 Got reply 1 to the command 1
. 2015-09-08 21:26:10.563 File: 'test.html' [2015-08-26T19:33:15.657Z] [48]
. 2015-09-08 21:26:10.571 Copying "test.html" to remote directory started.
. 2015-09-08 21:26:10.571 Binary transfer mode selected.
. 2015-09-08 21:26:10.571 Starting upload of test.html
> 2015-09-08 21:26:10.572 TYPE I
< 2015-09-08 21:26:10.732 200 Type set to I
> 2015-09-08 21:26:10.732 PASV
< 2015-09-08 21:26:10.857 227 Entering Passive Mode (79,96,115,79,239,130).
> 2015-09-08 21:26:10.858 STOR test.html
. 2015-09-08 21:26:10.908 Data connection opened
. 2015-09-08 21:26:25.963 Timeout detected. (control connection)
. 2015-09-08 21:26:25.965 Copying files to remote side failed.
. 2015-09-08 21:26:25.965 Got reply 1004 to the command 4
. 2015-09-08 21:26:25.965 Connection was lost, asking what to do.
No issues using other FTPS client.
Provider (home.pl) says WinSCP has an issue negotiating encryption for data channel.
Re: unable to upload or download files
Issue 1357 – Perform TLS/SSL handshake on transfer connection immediately when connected to Idea FTP server
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
gutek
Poland
Sent an email
Sent an email as suggested. You can send me back development version of WinSCP for testing. Thank you.
