Can't get WINScp running on remote ASP.Net MVC server
smorrison4@...
WINScp runs fine when I run it .NET C# on ASP.NET MVC locally, using the .NET wrapper, communicating with a remote SFTP server. But when I deploy it, it does read any files.
I tried making the winscp.ini file writeable, but that did not solve the problem. I have both the .dll and .exe in the bin directory. Any suggestons?
Steve
Re: Can't get WINScp running on remote ASP.Net MVC server
Please attach a full session and debug log file showing the problem (using the latest version of WinSCP).
To generate log file, set Session.SessionLogPath and Session.DebugLogPath. Submit the log with your post as an attachment. If you do not want to post the logs publicly, you can mark the attachments as private.
Guest eiv
I have the same problem
Logs Attached.
Please help.
EIV
  • 20160228_WinScp_SessionLogPath.log (3.84 KB, Private file)
  • 20160228_WinScp_DebugLogPath.log (42.88 KB, Private file)
Re: I have the same problem
It is most likely about privileges of the web server/web application. Try to increase them.
