-neweronly Switch
LoancareHD
Tidewater Virginia
-neweronly Switch
When trying to connect to a remote user and use the -neweronly switch we receive the message "Unknown switch 'neweronly'.
The script command is
option echo off
option batch on
option transfer auto
option batch continue
option batch on
option transfer binary
option exclude *.tmp
put -preservetime -neweronly "F:\SFT\Reports\folder\Reports\*.*" "/Inbound/Reports/"
close
hendra
Re: -neweronly Switch
i have install the latest version of winscp (5.15.2),
my script was "get -neweronly /path/* c:\file\" "exit"
but still got the same error. Unknown switch 'neweronlyt'
You will hardly get an error referring to neweronlyt for a command that does not even contain that keyword. The problem must be elsewhere.
  • winscp.log (40.63 KB, Private file)
Description: here is log file
I have asked for a log from the latest version of WinSCP. You are using WinSCP 5.1.4, which is over 5 years old and does not support -neweronly.
