Using WinSCP to access IpSwitch MoveIt site?
cboshdave
United States
I work with a group that is providing me daily files via a MoveIt. I would like to automate my downloads. I am trying to connect to the site with a normal sftp client. I cannot seem to get it to work though? I guess the first question is, should it work? Is there anything weird I need to do to connect? What Port? Normally it is 22. The address starts with an https://moveit... does that need to be adjusted? I just keep getting errors. Not sure what to "fix".
Re: Using WinSCP to access IpSwitch MoveIt site?
I do not know MoveIt.
The https:// may indicate WebDAV protocol (WinSCP supports that).
Or it's a proprietary web-based system. Then you are out of luck.
