Powershell script from SQL Server Agent giving "'Add-Type' is not recognized" error
I adapted the WinSCP PowerShell example to upload a file and it works perfectly from powershell.exe. I then created an SQL Server Agent job to run this script but it's failing on the try-catch block with the error: "The term 'Add-Type' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again."
In my agent job step the Type is set to PowerShell and I just pasted the script from the .ps1 file that works from the command line. This is on SQL Server 2008 R8. Has anyone seen this before?
