Weird bug with opening and reloading some files
youradds
UK
For some reason (since the last update I think), I've been getting weird errors like:
Can't create file 'C:\Users\Andy\AppData\Local\Temp\scp02808\srv\www\site.net\www\cgi-bin\admin\templates\shared\Directory\modify_dir.html'.
System Error. Code: 1224.
The requested operation cannot be performed on a file with a user-mapped section open
I also get errors when trying to save the files in my editor. I have attached 2 screenshots for you, to show what I get. Hope that helps!
Anyone got any ideas?
FWIW I upgraded to Win10 recently - but it was working fine for a while since then. It only seems to have become an issue with the last upgrade I did.
TIA
Andy
Description: Message when trying to save a changed file
Description: 2nd message I get (when trying to re-open the file)
Re: Weird bug with opening and reloading some files
Do you get this every time or randomly? What upgrade do you mean? Upgrade of WinSCP? From what version?
youradds
UK
I'm now on 5.7.4 (not sure what I was on before, but I do remember upgrading recently)
I can't seem to see a pattern - but if I do, I will let you know :)
Cheers
Andy
