Upload file with timestamp
mguizzetti
I have a file created daily with a file name filename_yyyymmdd.zip. I've not been able to get my script to recognize the filename with timestamp when uploading. Below is my "put" line, any ideas?
Put "\\loacalserver\automation\filename_%%TIMESTAMP#yyyymmdd%%.zip"
Re: Upload file with timestamp
How do you use the put command? If in a script file, use single % only:
put "\\loacalserver\automation\filename_%TIMESTAMP#yyyymmdd%.zip"
If that does not help, attach a full log file showing the problem (using the latest version of WinSCP).
