WinSCP - Fantastic Product
duerra
I just happened to stumble across WinSCP today, and was absolutely blown away. It is a fantastic product that does almost anything I've wanted from an SCP client. I'm most gracious for the time and effort put into the product.
A couple of things that I haven't seen that would satisfy my every last desires.... :)
  • Many mice today have the buttons on the right and left and side. Explorer uses them for navigating back and forth in directories, and most browsers use them to go forward and back on web pages. This would be nice for WinSCP, since I'm kind of (ok, very) addicted to navigating like that =P
  • It would be really *really* nice to have right-click menu options in the open area of either local or remote windows for some usually options - namely "reload", so that I don't have to peek around for the reload button on the task bar.
That's it.... just two little things. My donation should be arriving shortly :)[/list]
Re: WinSCP - Fantastic Product
Good idea. I'll do that. Or at least I'll try.
OK, maybe :-)
duerra
Thanks, prikryl. I any more about you than what I've seen from glancing around the forums, but from what I've seen, you strike me as a very genuine and helpful individual.
_________________
When you put everything into something, it means everything to you.
