Invalid access to memory - void * * std::_Copy_opt<void * *, void * *>
niedziolek@...
I have been connected remotely to the Linux Machine by SFTP. I had 4 files(.log extension) opened for a longer while. I have decided to close them all one by one, first one was closed correctly, on second one i noticed the error. Later i have closed rest of them and it went fine. I have been doing same action for a lot of time and it's first time i can see any kind of error in your program, it's very good. Thank you for working on it.
Naruszenie ochrony pamęci - This in Polish message means Violation of memory protection.
WinSCP 5.7.1
Naruszenie ochrony pamęci.
[0018A85D] void * * std::_Copy_opt<void * *, void * *>
[00911962] C4799_0
[009139CA] ____ExceptionHandler
[00910944] __ExceptionHandler
[7702B67A] ntdll.dll
[76FE015E] ntdll.dll.KiUserExceptionDispatcher
Re: Naruszenie ochrony pamęci - void * * std::_Copy_opt<void * *, void * *>
Are you able to reproduce the problem?
kevin.broderick@...
Go find an xml file on a remote computer via WinSCP, go to edit that file just to view it. When done, close the edit window by the (X) on the top right and the hour glass takes considerable time before the window finally closes.
WinSCP 5.7.6
(00059C79) void * * std::_Copy_opt<void * *, void * *>
(007E46BA) C4799_3
(007E369C) __ExceptionHandler
(0005A7EA) ntdll.dll
Re: Invalid access to memory - void * * std::_Copy_opt<void * *, void * *>
The issue is reportedly resolved in WinSCP 5.8.2.
zyczuplayers@...
WinSCP 5.9
(00064B8D) void * * std::_Copy_opt<void * *, void * *>
(0086216E) C5073_3
(008641D6) ____ExceptionHandler
(00860F90) __ExceptionHandler
(00081D3F) ntdll.dll
nattapol.kritsuthikul@...
WinSCP 5.9.6
(00064D95) void * * std::_Copy_opt<void * *, void * *>
(008689AA) C5077_0
(0086AA12) ____ExceptionHandler
(008677CC) __ExceptionHandler
(000851CF) ntdll.dll
lcr073@...
Acesso inválido à memória - void * * std::_Copy_opt<void * *, void * *>
WinSCP 5.11.2
Rastreamento de pilha:
(00065065) void * * std::_Copy_opt<void * *, void * *>
(0089C9C2) C5067_3
(0089B7E4) __ExceptionHandler
(00062496) ntdll.dll
gupta.santoshl@...
WinSCP 5.11.1
(00065061) void * * std::_Copy_opt<void * *, void * *>
(0089C862) C5067_0
(0089E8CA) ____ExceptionHandler
(0089B684) __ExceptionHandler
(0006248E) ntdll.dll
david.dwinell@...
WinSCP 5.13.2
(00066795) void * * std::_Copy_opt<void * *, void * *>
(008BC642) C5104_0
(008BE6AA) ____ExceptionHandler
(008BB464) __ExceptionHandler
bornukov-e@...
Ошибка доступа к памяти - void * * std::_Copy_opt<void * *, void * *>
WinSCP 5.14.1
Ошибка доступа к памяти.
Трассировка стека:
(0006F4A9) void * * std::_Copy_opt<void * *, void * *>
(008FA2C6) C5107_3
(008FC32E) ____ExceptionHandler
(008F90E8) __ExceptionHandler
(0007DAFF) ntdll.dll
igor503@...
WinSCP 5.13.1
Трассировка стека:
(00065915) void * * std::_Copy_opt<void * *, void * *>
(008BA3F6) C5101_0
(008BC45E) ____ExceptionHandler
(008B9218) __ExceptionHandler
(0008A63F) ntdll.dll
lozusharez@...
WinSCP 5.13.2
(008BC642) C5104_0
(0008341F) ntdll.dll
jim@...
I left the app to upload files to my remote server; when I returned to the app from another the error message was displaying
WinSCP 5.14.4
(00070465) void * * std::_Copy_opt<void * *, void * *>
(00926AFE) C5156_3
(00928B66) ____ExceptionHandler
(00925920) __ExceptionHandler
(00083FFF) ntdll.dll
mahmoud.elzouka@...
WinSCP 5.15.1
(0007051D) void * * std::_Copy_opt<void * *, void * *>
(0092636E) C5153_3
(009283D6) ____ExceptionHandler
(00925190) __ExceptionHandler
(00087C8F) ntdll.dll
ralph.t.casasanta@...
WinSCP 5.15.2
(00070669) void * * std::_Copy_opt<void * *, void * *>
(0092709A) C5157_3
(00929102) ____ExceptionHandler
(00925EBC) __ExceptionHandler
(00045CD6) ntdll.dll.RtlRaiseStatus
(00045B62) ntdll.dll.KiUserExceptionDispatcher
chiraggoel.it@...
WinSCP 5.15.3
(00070751) void * * std::_Copy_opt<void * *, void * *>
(0092770A) C5157_3
(00929772) ____ExceptionHandler
(0092652C) __ExceptionHandler
(0008402F) ntdll.dll
harika.haru55@...
WinSCP 5.15.5
(0007076D) void * * std::_Copy_opt<void * *, void * *>
(0092827A) C5157_3
(0092709C) __ExceptionHandler
janispickel@...
Zugriffsverletzung - ungültiger Zugriff auf den Speicher - void * * std::_Copy_opt<void * *, void * *>
WinSCP 5.17.5
(00071241) void * * std::_Copy_opt<void * *, void * *>
(00F87C7E) C5296_3
(00F89CE6) ____ExceptionHandler
(00F86AA0) __ExceptionHandler
(00087E3F) ntdll.dll
Re: Zugriffsverletzung - ungültiger Zugriff auf den Speicher - void * * std::_Copy_opt<void * *, void * *>
lidiia.fatii@...
WinSCP 5.17.7
(00071369) void * * std::_Copy_opt<void * *, void * *>
(00F8862A) C5296_3
(00F8A692) ____ExceptionHandler
(00F8744C) __ExceptionHandler
lidiia.fatii@...
WinSCP 5.17.7
(00F8862A) C5296_3
prasanna.gabbita@...
WinSCP 5.15.9
(00070789) void * * std::_Copy_opt<void * *, void * *>
(0092812A) C5157_3
(00926F4C) __ExceptionHandler
(0008421F) ntdll.dll
alencosv@...
WinSCP 5.17.10
(00071381) void * * std::_Copy_opt<void * *, void * *>
(00F8A13A) C5296_0
(00F88F5C) __ExceptionHandler
kampcio515@...
Nieprawidłowy dostęp do pamięci - void * * std::_Copy_opt<void * *, void * *>
i closed a yml config file using the 'X' button. It lagged for a white and I got this error.
WinSCP 5.19
(00075665) void * * std::_Copy_opt<void * *, void * *>
(00FBBC06) C5294_0
(00FBDC6E) ____ExceptionHandler
(00FBAA28) __ExceptionHandler
(0008788F) ntdll.dll
pink.floydowich@...
WinSCP 5.21.5
Трассировка стека:
(0007728D) void * * std::_Copy_opt<void * *, void * *>
(00FDC86E) C5412_0
(00FDE8D6) ____ExceptionHandler
(00FDB690) __ExceptionHandler
(00056FDE) ntdll.dll
elia.finotti@...
Accesso alla memoria non valido - void * * std::_Copy_opt<void * *, void * *>
When I click icon to close a file not edited and not modified
WinSCP 5.21.7
(00077295) void * * std::_Copy_opt<void * *, void * *>
(00FDF7C2) C5412_0
(00FE182A) ____ExceptionHandler
(00FDE5E4) __ExceptionHandler
(00097E4F) ntdll.dll
(000760C1) ntdll.dll.KiUserExceptionDispatcher
charlieboswellbuisness@...
WinSCP 6.1.2
(0007F8C9) void * * std::_Copy_opt<void * *, void * *>
(01003DEA) C6083_0
(01005E52) ____ExceptionHandler
(01002C0C) __ExceptionHandler
(00087A7F) ntdll.dll
fajinafsal@...
WinSCP 6.1
(0007F7C9) void * * std::_Copy_opt<void * *, void * *>
(01004C0A) C6085_3
(01006C72) ____ExceptionHandler
(01003A2C) __ExceptionHandler
(00087A6F) ntdll.dll
