scripted synchronize fails to properly follow local symlinks to PDF files, and *only* PDF files
TysonD
Indianapolis, IN
I have WinSCP configured to synchronize several local directories to my server via FTP. The files on the server never change; only the local files and directories change (for now.) The local directories contain symlinks to various folders and files.
Everything works as expected *except* the way WinSCP resolves symlinks to local PDF files, and *only* PDF files.
The WinSCP log indicates that every time it checks a symlink that references a PDF file on my local machine, it thinks the file has changed (they have not...) and initiates a STOR rather than simply skipping over that PDF file.
When WinSCP checks symlinks to folders and other file types (.jpg, .doc, etc.) it syncs as expected; i.e. if the local file referenced by the symlink hasn't changed, WinSCP skips that file and does not initiate a STOR.
Here's my script:
/console /command "open ""hubHTML 10837""" "synchronize remote ""-filemask=|*h5ai;*.htaccess;*.TBD*/;*h5ai/"" -delete" "exit"
...and I've attached the log file. Note that the only files that get transferred are PDFs. Here is the full list of local files that are referenced via symlink:
10837 Basement Seattle DPD ADU Removal Modifications 04-2013.docx
10837 DOWNSTAIRS Renovation Budget.xls
10837 Electrical & Plumbing Summary Letter 06-22-05.doc
10837 Gas Piping Permit 11-07-12.pdf
10837 Maintenance.xlsx
10837 UPSTAIRS Remodel Expenses 02-25-06.xls
2003 10837 Assessment.pdf
2013-10 10837 Craigslist ad photo 012 10837 Annual Inspection 08-2007 017 (Large).jpg
A Portrait of Your Old House.doc
Correction Notice #1 11-30-11.pdf
Seattle House Research Resources.pdf
Seattle Parking Ticket 325360659 11-07-12.pdf
Thanks for any insights.
WinSCP 5.7.5
Windows 7 Pro
  • hubHTML-10837.log (1.93 MB, Private file)
Re: scripted synchronize fails to properly follow local symlinks to PDF files, and *only* PDF files
I assume Seattle Parking Ticket 325360659 11-07-12.pdf is one of the problematic files, right?
TysonD
Indianapolis, IN
Yes, that's correct. I'll download the debug version and set up a test scenario then report back with the logs.
TysonD
buggy Windows symlinks
Thanks Martin-
Please let me know if I can assist with any additional testing. I suspect, as you do, that the issue is with the way some Windows APIs handle symlinks.
TysonD
Indianapolis, IN
Hello again Martin-
FYI, I replaced my Windows file-symlinks with file-hardlinks and everything seems to be working fine now. Windows symlinks seem to work much better for folders than files; junction points also work well for folders. There have been several recent Windows Updates that have 'broken' Windows 7 symlink functionality, so I think using hardlinks whenever possible to link to files rather than symlinks is preferred.
Link Shell Extension is a great utility for creating and managing links in Windows.
https://schinagl.priv.at/nt/hardlinkshellext/hardlinkshellext.html
