synchronize remote issue
I'm trying to setup a scripted job to copy some log files from A to B however I'm having some issues... see the details below.
The script I am running is this -
"open sftp://username@x.x.x.x/
synchronize remote D:\Directory\Backups\2015_08_09\Directory\2015_08_09\Directory
exit"
The problem I have is that the file path changes daily to include a date in the folder path.
I've tried using the path masks but I get the following message from the WinSCP console - "Nothing to Synchronize"
If I enter the exact file path the directory sync's without problem.
justcallmedanny
exit"
justcallmedanny
