EF
Install client certificate?
Communicating over FTPS with a bank - they require FTPS with username and password, plus require installing an x509 certificate on the client (they provide this cert). Can't find anywhere in WinSCP to install certificates or assign certificate for use with a specific FTP site. Is this possible?
Site Admin -
- 42,636
- Prague, Czechia
Re: install client cert?
The client certificate support is not released yet:
Issue 921 – Authentication with TLS/SSL client certificates
- ftpuser
- 2
When will this functionality be released as I see from the bug tracker it is implemented and in release 5.8
Site Admin -
Sorry, we do not give any dates. It will take a few weeks definitely.
We can provide you a development build for testing, if you are interested.
- astronaute
- 1
Hi prikryl,
Can you please give me the development build, I would like to get rid of Bitkinex :)
Thank you !
Thank you !
Site Admin -
@astronaute: Sent.
- robertb
- 3
- Montana
Need to connect to FTPS with certificate as well
Is this available yet?
Have the same issue. Please help.
Site Admin -
@robertb: It was not released yet. I've sent you a dev build.
- RobHeffo
- 2
- Albury, Australia
Dev Build Request
May I also please request a copy of the DEV build with Certificate support. I also have a requirement for this feature.
Thanks!
Robert Heffernan
Thanks!
Robert Heffernan
Site Admin -
Re: Dev Build Request
@RobHeffo: Sent.
- finist
- 1
Could you kindly send me a copy of the DEV build with Certificate support too?
Thanks!
Thanks!
Site Admin -
@finist: Sent.
- Sujeet
- 7
- Pune, India
Want to use x509 client certificate while upload/download files win WinSCP from client network in c#
Hi @martin,
We want to attach client certificate with WinSCP for file uploading because client network do not allow anything to go out without that client certificate.
Could you please help us or let us know if you have released the newer version of WinSCP which supports client certificate.
Thanks,
Sujeet
Thanks,
Sujeet
Site Admin -
Re: Want to use x509 client certificate while upload/download files win WinSCP from client network in c#
Thanks @martin.
Do you have any sample code with you for how to attach the certificate with WinSCP session?
Site Admin -
@Sujeet: Use
https://winscp.net/eng/docs/library_sessionoptions#tlsclientcertificatepath
SessionOptions.TlsClientCertificatePath
- Sujeet
- 7
- Pune, India
Thanks @martin, but I am not able to find given property
However is there any way to attach certificate directly as we don't have path of certificate with us, we have to pick installed cert by its name provided from machine. We do attach the same to web reference like
Could you please help us for this.
Thanks.
TlsClientCertificatePath with WinSCP576automation.
WebServRef.ClientCertificates.Add(cert) where cert is the X509Certificate object.
Thanks.
- Sujeet
- 7
- Pune, India
My Bad...
Found given property in WinSCP 5.8 Beta.
Could you please help me with my another query, is there any way to pass/attach certificate by object and not by path.
Site Admin -
No, this is not supported.Could you please help me with my another query, is there any way to pass/attach certificate by object and not by path.
- RobHeffo
- 2
- Albury, Australia
Argument Exception
Hi, I am finally getting around to trying to use this code and am getting the following error...
The code I am using to create the session options is....
I can't see what is wrong here. The TLS Client Certificate is a PPK file, the host key is copied from WinSCP
Any suggestions?
Any suggestions?
Site Admin -
Re: Argument Exception
The .ppk file is not FTP TLS client client certificate, it's SSH/SFTP private key file. Use
SessionOptions.SshPrivateKeyPath.
Onur
FileTransfer using WinSCP to/from Windows site which use FTP SSL(TLSv1)
Have you published any example PowerShell code for this please?
Regards,
Onur
Regards,
Onur
Site Admin -
Re: FileTransfer using WinSCP to/from Windows site which use FTP SSL(TLSv1)
@Onur: Use Generate Code function of the latest beta version:
https://winscp.net/eng/docs/ui_generateurl#code
- Guest
Thanks a lot, it rocks :)
Regards,
Onur
Regards,
Onur
