Can't copied file to my FTP server
solaris
When I tried to transfer some file to my server, it doesn't work.
I have to desactivated my firewall and after this it's work.
How to fix this issue?
Thank you in advance for your help.
Re: Can't copied file to my FTP server
You have removed the log header, so I cannot see what version of WinSCP you are using.
Can you transfer the files using any other FTP client?
solaris wrote:
I'm using the last version.
I think I have issue with my firewall, but I don't now how to authorize the port of winscp on my firewall.
It does not look like a firewall issue, as you are able to retrieve a directory listing.
