Trying to parse XML log.
Hello, I am using msxsl.exeto attempt to parse out the information I need. What I want to do is be able to send the out put to a txt file so I can use it in my batch scripts.
The xml log is as shown.
<?xml version="1.0" encoding="UTF-8"?>
<session xmlns="https://winscp.net/schema/session/1.0" name="user@server.company.com" start="2015-08-03T18:31:36.636Z">
<upload>
<filename value="D:\SIT\VendorTransmissions\WSC_Transmission\outgoing\Prntelec.r.zip" />
<destination value="/connect2/WSCSuppression/Consolidated/Prntelec.r.zip" />
<result success="true" />
</upload>
<call>
<command value="/connect2/WSCSuppression/wsc_transmission.sh " />
<destination value="/connect2/WSCSuppression/" />
<output value="Start of Connect Direct session for WSC transfer
End of Connect Direct session for WSC" />
<exitcode value="4" />
<result success="false">
<message>Command '/connect2/WSCSuppression/wsc_transmission.sh '
failed with return code 4 and error message
.</message>
</result>
</call>
<failure>
.</message>
</failure>
</session>
The XSLT file I have so far is
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:winscp="https://winscp.net/schema/session/1.0">
<xsl:output method="text" encoding="UTF-8"/>
<xsl:strip-space elements="*"/>
<xsl:template match='winscp:call[winscp:result[@success="false"]]/winscp:exitcode'>
<xsl:value-of select="@value"/>
<xsl:text>
</xsl:text>
</xsl:template>
<xsl:template match='winscp:call[winscp:result[@success="false"]]/winscp:result'>
<xsl:text>
</xsl:text>
</xsl:template>
</xsl:stylesheet>
What I would like to have is to disply the exitcode tag and it value and then the result success value.
Example of output needed.
exitcode:4
result sucsess:false
Closest I get with above xslt is
4
I would even take a VBS soultion as well that I could use to read through the xml log and grab what I need.
Edwin
<upload>
</upload>
<call>
.</message>
</result>
</call>
<failure>
.</message>
</failure>
</session>
<xsl:text>
</xsl:text>
</xsl:template>
<xsl:text>
</xsl:text>
</xsl:template>
</xsl:stylesheet>
exitcode:4
4
Edwin
